Who has a lift in their garage?
I went with a 4 post lift with the ramps . My ceiling is like 12 feet.
got the lift from Pace tools 1,700 .installed it with 2 friends in about 3-4 hours .
When fully extended up theres feet of space under it .I felt more comfortable with a 4 post.I sure 2 posta are just fine .i use mine mostly for storage .I must say it bings a new concept to keeping my cars clean,nevr have to bend over again.
Put heated floors in as well as heat and A/C. I spend hours in the garage.
NOW ALL I NEED IS SOME PROPER GARAGE CABINETS AND A TIRE RACK ANY IDEAS WHO HAS THE BEST DEAL??
Sears has a nice product line from "Stack-ON" that I really like. They're powdercoated black and made of metal with adjustable shelves. You can get them in a couple of different configurations.
My goal was to have as little as possible on the floor that wasn't attached to wheels so it could be rolled out. We're very pleased with the way our shop turned out.
Mike
Mike
12 FT. should be plenty take a look at some lifts and go from that. I am in the process of planning a detached two car garage/shop and 12 feet will accommodate a tall 2 post lift.
http://www.gregsmithequipment.com/Ve...Lifts-s/37.htm
Mike
This brings to mind something stupid that I did. I have a two story garage and I bought a 15' tall lift and put a ramp on it so that I could raise a car all the way up through a hole in the floor to the second story. The custom lift came and we installed it and I pressed the up button, waiting to see the car go up through the hole. The car only went up 6' . In looking at the lift, I quickly determined that due to the lengths of the rams, the car would never be able to go any higher.
I called up the lift manufacturer claiming that I had been ripped off. I asked why they would make a 15' tall lift that only went up 6' and he asked me "How tall is your mechanic "? The lift was for vans and such...
All great set ups. I went a slightly different direction since I do not do hard core mechanicals on my car I installed a brake lift that raises the car approximately 4 feet so I can change suspension, brakes, etc. Space/storage was not a consideration as I have it in my warehouse.
I use a four post lift and regularly remove the wheels on the car that I'm working on. It is a bit of a pain, but considering the need for both "stacking" and working on the cars, it works out fine.
My ceiling height is limited. 9' 8" IIRC. But it gets the car up high enough to comfortably do everything from rod bearings, clutch, exhaust, etc.
I have a garage with a 9.6" foot ceiling height. The 3rd bay is a tandem so no garage door to worry about. I have calcuated I could just barely fit my lower 944 race car over my 944 Turbo. I don't believe I have space to put my 530 E39 under there however. I have yet to put in a lift and may never do so, but I have calucated out what I may take. That was done assuming a 4 post lift with a carefull eye on space requirements. If I needed to work on the car with a lift I think a mid rise would work much better for me.
I have a Liftmaster Jackshaft lift and it pulls the garage door straight up along the roofline. The garage door opener itself mounts to the garage door shaft on the wall next to the garage door. I don't have a good picture right now,but you can see from this one that there isn't an opener anywhere in view. I'll get a couple shots tonight and post them as I am quite happy with the set-up.
Part of the IN Crowd
http://www.liftmaster.com/consumerwe...lJackshaft.htm
It works like the commecial openers, but has all the residential features. Mine has memory remotes, a motion sensor for the lights, electronic door locks and the wall mounted button has the time and garage temp on it. Mine also came with a battery back-up so it will still work when the power goes out.
On the concrete, it varies by lift manufacturer/style. For my 10,000lb 2 post rotary it is 3,000psi and 4 1/2inches deep.
