Calabogie Motorsports Park Video
NASA Racer
One suggestion for setup changes, go big not small. For example, do one session with front tire pressure significantly higher than normal and see what happens. Play with that and then go full stiff on the front bar and work your way back. Then move on to the rear bar, but use large initial increments and move back.
Are you running Hoosiers?
I use Kumho Victoracers or MPSC, depending on my mood when I buy tires. I'm going to try the Nitto in 08.
A note to those who have not driven there;
Think Mid Ohio. That is the closest I can come up with in terms of style (in some respects. In others, not even close). If you have driven Mid O, you will know that there are many places where it is very easy to lose time, and very few where you can make it up. You have to save your testosterone for 1, 6, & 13, and learn to temper your enthusiasm everywhere else.
Calabogie is very much more so. It is a track of immense subtlety. It rewards patience and finesse more than bravado.
- I'd say you need to set the car up with a bit more static oversteer for Calabogie. Those long drifting corner complexes allow a very hot entry, with a dirt-track style drift to scrub speed. If you can go in there hot with the tail just slightly stepping out, you can really haul the mail going in, time your rotation with steering input, and hammer the gas at just the right moment for exit. I've never encountered a turn that teaches you this better than Temptation.
- Can you drop the 2 gears going into Mulligan's? Or perhaps going in as suggested above will put you at a higher RPM for accel?
- I'd let the car track full left between 12b and Throat. That is where it naturally wants to go. Since Throat is a slow turn, it is not at all hard to negotiate it from the left side of the track. I'd bet most people could gain a tenth right there. It looks like you did this more so on the 2nd lap.
This is a few laps from earlier in the summer (http://www.youtube.com/watch?v=-Nwk9kpu148) when the setup had a little more oversteer (note: the viper wasn't supposed to give me a signal)
Shift mid-tiurn...its no big deal really.
You are describing slip angle. You have to be on the throttle hard in order to generate it, and its the different between fast & slow. I suspect that if you would generate more slip angle, the understeer feeling would go away.
Even better than taking rides, hire a pro/instructor for a day or 1/2 day. Get them to drive your car and compare the data. You'll learn far more than spending another $1k on go fast bits.
Try skip shifting...just go 4th direct to 2nd.
One thing that I've noticed when riding in other instructors cars that are similar (i.e. 964's etc) is that when they are accelerating out of the corner, the rear slips just enough to give the car some rotation. I cannot seem to do this with mine (I understeer on throttle at corner exit). I don't know if it's a driving style thing, a HP thing (I have 185 lb/ft & 200hp at the wheels) or a setup thing (i.e. I don't have a LSD).
Actually, it is a big deal in a Targa. If I'm not straight (or close to it), I can't get the car into 3rd. It's always been that way. I assume it's chassis flex or the 20 year old transmission mounts (I've been thinking about solid mounts for the gearbox). It's the reason I never use second gear anywhere (except 5b at Mosport).
yes, but the problem is that I'm flat out from the apex. It may be a product of using too little rpm out of the corners. Maybe I'll revisit trying to use 2nd again.
I agree. I think some dedicated coaching would go along way. I've asked other instructors that I trust to drive my car to get sample data, but they are not comfortable pushing someone else's car that hard (which I understand since I decline to drive student's cars).
I'm typically not a skip-shifter (it's mostly a timing thing), but maybe I'll start trying to use 2nd again. Maybe I just need to sell my bolt in cage and put in a welded one to stiffen the chassis more.
OK;
Good points you made. Setting up the car to understeer is necessary for trail braking. The rub is getting yourself to commit to that much more entry speed!
- So, what's with the lift in Kink? You know you can do it flat. Little LFB tap, or a flick of the wheel, if the front floats on you.
- You could probably TB Jacques pretty heavily. Most of the track doesn't reward heavy, aggressive braking, I don't think. That might be the only place where threshold braking would be applicable. However you do it, you certainly don't want to get fouled up for Gilles!
- I take a differnt line into Temptation. You seem to stay very tight past the entry apex curb. I clip that same curb in the same spot, but then head directly all the way out to the turn in cone. I do my heavy braking/shifting after that entry apex, and then begin to dial in steering as I near the track edge. Great natural rotation ensues, and if I time it just right all that is left is to mash the gas and exit the turn. It also helps when Botho is not spun and facing you at the exit curb!!!
- You're right about all the junk entering throat. To many people ripping up tires trying to stay right!!
You certainly had the measure of that Viper, in all ways but grunt... and smoke!
OK;
The guy in the Viper is a friend (he has 3 ACRs, and they all smoke like that), and he's been working on increasing his pace, so I went out behind him to video his run. He made big gains this summer.
One thing I did notice this year was that when I was running MPSC during the summer, the more I slide the car (with a loose setup), the faster it was (both laptimes and tirewear) with a best of 2:24.4. With the Victoracers, my best laps (a 2:24.6 set earlier in the day of the first video) were done with a mild understeer setup and very little sliding. So is sliding faster or not? I've seen John drive. He's fast and he slides a fair bit, and others here that are fast have also mentioned they slide the car a lot. Is it just a factor that MPSC like to slide and Victoracers don't (tire temps are 170's in the front and 180's in the rear in both cases). How much do you slide?
Can ya tell the winter is starting to get to me? I've even started modifying my 4 year old's PowerWheels pickup.
