Eagle Canyon Raceway Video
#46
Which group and run was it in? In the 3rd White session, there was a debris flag and a minor smell from the track through 2 corners.
#47
Oh, OK, thanks, Sean. My rev limiter is at 7,000 RPM, however, and I don't have cams. Dan at Diffs Online thought that a 3.73 would top out at barely 140mph at 7,000 RPM's at TWS....andI don't like hitting the rev limiter. I think I am gonna opt for the 3.46 since I have a lower rev limit and no cams. Sure will be a lot better than the stock 3.23.
Greg, yeah, Stuart is a very good driver. I am glad you hooked up with him. He has done a LOT of work to that car suspension-wise ot get it to drive the way it does, including a special TC Kline suspension specifically designed for that car. I drove his car at Barber Park and it is a true delight. He and I usually run nose to tail wherever we go, unless one has a passenger & the other doesn't, or vice versa.
To address your earlier question, I considered taking the car off track into the dirt, but I didn't want to, and since I was able to keep it running at low RPMs in high gear & made it back to the pits, I did. Stopping a hot car on dry grass is a BIG problem. When in doubt in a broken down car, stop on asphalt...
#48
OK, thanks.
#53
Greg,
I looked - and found you in Turn 9 right in front of the red GT3 #190.
http://homepage.mac.com/ervtx/.cv/er...R6.mp4-zip.zip
4.8meg download
I follwed that red GT3 almost the entire session... what a beast!
4.8meg download
#55
'Cause that's how I roll---I am a giver.
Greggie, you wish. You do understand the term "lead and follow", right?
#57
-Russell
#58
#59
http://homepage.mac.com/ervtx/.cv/er...ay.mp4-zip.zip
