How available are 993 factory cup cars?
#47
The primary differences are going to be engine torque from 3.8l, much better gearing (may be the most significant contributor), wider tires, and the GT2 Evo uprights in the front. The later Cup wing also produce more downforce in the faster corners. I think that if you regeared a 964 Cup trans you'd find another 1-1.2 seconds at a track like WGI.
#48
I've raced with a lot of the 964 cups and I must say that given an equal run out of the corner they are quite close when it comes to straight line speed. The biggest difference in my opinion is the handling. With the multilink rear suspension the 993 seems to be a lot flatter in the corners whereas the 964 exhibits the typical 911 inside front tire in the air. I think this is Charles Boyer behind me.
-Phil Gilsdorf
-Phil Gilsdorf
#49
-Phil Gilsdorf
-Phil Gilsdorf
#52
#55
#57
Brant,
I would change 2-5 in the cup G50/10 gearbox, however, it will not be legal for GTC-1 in PCA any longer and will put you into GT2R to run with cars like mine...
I think the stock springs/dampers work extremely will in the 964 Cup and you have enough adjustability to change the handling characteristics to meet the driver's needs. Further, I think the latest cup valving works better than the earlier valvings. I've also driven a 964 Cup with higher rate springs and dampers and didn't think it handled as well as the stock setup.
I'm don't subscribe to the theory that stiffer springs and shocks are necessarily better. The 200- 600/240-800 spring rate on the 964 cup is actually progressive and allow the car to be run on multiple types of surfaces without having to adjust a nonadustable suspension setup. The 993 Cup may run stiffer springs, however, the rear suspension also has geometry that changes with ride height and does not like to be lowered. A stiffer spring will keep the car's geometry from changing as much as with a softer spring. It may have been used to overcome this geometry issue.
