Electric or Hydraulic Surge Brakes on Trailer
Looks pretty nice. Strange that it does not show the whole tung but it looks to me like an electric controller behind the jack? It has the aluminum wheels which are nice. If you buy it, get a spare tire (or two) and a carrier to mount them to the trailer. +1 on talking to Karl, great guy. Also, it looks naked without a tire rack
Good luck!
uninformed gas bag
(contemplating on whether gas bag is one or two words)
NJ requires anything over 3k requires brakes. I am running Electrics on my trailer because thats what it came with. I also own 20 trailers that have surge brakes in my rental fleet. I can go either way. Boat trailers that have surge brakes that don't work is a result of poor maintenance i.e. corrosion.
I also inquired about a new trailer. Carl definitely sweetens the purchase for us PCA folks. I'll consider new if something used doesn't work out. Trailex is also only a couple hundred miles from me which is quite nice.
So the tire rack is kind of like lingerie? This trailer stuff sounds fun
![ooops](https://rennlist.com/forums/graemlins/icon501.gif)
Mike
LOL! I guess you could consider the tire rack a bra
I am going to be looking at it in a whole new light while towing to Mid O tomorrow!
If you can get that used one at a good price do it as used Trailex are very hard to find. If not, new will be North of 7K but they hold their value well.
A lot of this relies on what your tow vehicle is. My 3500 dually is able to stop fine (not as well but fine) even if the trailer brakes stop working, this is towing a 2 car open steel trailer total rig at 9 tons.
On a small SUV I think I'd prefer surge brakes because if something fails in the trailer electrical and you lose brakes, chances are you won't be able to stop. My definition of small SUV is Tahoe or less.
Trailer electrical systems are the most annoying systems on the planet. Blown bulbs, bad grounds, unreliable plugs, inconsistent colors, etc.....
I am curious as to how the Trailex surge trailers don't effect your backing ability especially if you are backing up any kind of grade. Does anybody know how the trailer knows the difference between backing and slowing down?
Not sure on the Trailex, but the surge brakes on my friend's boat trailer has a solenoid (electric release valve?) which relieves the hydraulic pressure. Trailer has a 5-pin connector. 5th wire goes to the back-up lights - when vehicle is put in reverse, the solenoid opens to relieve brakes and you can back up, even uphill, etc.
I guess I'm late to the party... But have had great luck with the surge brakes on my used trailex - of course, when I bought it I had to replace the master cylinder, damper, brake lines and wheel cylinders...
BTW, I believe it's the damper that helps in backing up (at least on the old ones). It's a little shock absorber to smooth out the master cylinder action - you have to be going really fast in reverse or backing up a pretty steep hill before the brakes actuate.
I've also delt with Ken Montgomery at Trailex for parts and advice and found him to also be a top-notch guy.
