Info Needed on Building '00 Boxter into F-Stock
Primary reason is overall safety. While I am not fast I am going faster and I like the idea of a purpose built cage that is designed to maximize internal dimensions. No complaint on the bolt in I just want a little more. The car has been on a rather severe diet and the addition of the cage and deletion of the soft top and assorted bits will yield additional savings. FG skin being installed for top. Once I pull it out I will maike it available at fire sale $$ for anyone that can find a good home for it, fellow club member did the same for me.
If possible please take some pics of the cage build out.
I have an '03 S and was thinking of converting it into a track car (If my wife will let me) someday as I absolutely love how the car handles and the extra 50 or so HP over my S2 would be nice too!
I would also be interested in what weight you can get the car down to and what you had to do to get there. PM me if you'd rather.
Thanks.
Eddie:
racers rule number one: It is always easier to ask for forgiveness than permission.![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
I will put together image archieve. This weekend I am plumbing in lift at my office and sorting out trailer for Sebring.
Cheers
Cheers
Cheers
Cheers
![ooops](https://rennlist.com/forums/graemlins/icon501.gif)
However I can offer shop ac, beverages, music, and if my other friends have their way a s-pole.
Christian,
Are you building your Boxster for F Class? If so, what do you think it would cost to build one into a competitive car? Assuming doner is stock.
Thanks for all the info. Does anyone know if removing the factory soft top and motors is legal in F Stock? It seems this would almost have to be done to install the cage and would nicely remove some weight (and allow to recoup some build cost).
Second question how much rubber can fit under the Boxter? 245/275?
Also why are the shocks so expensive for Boxter/Cayman? Moton doubles are $7k :O ! Is there something inherently complicated in the suspension design?
Also, even if you remove the soft top and motors, I don't think you'll actually save weight unless you run with no top at all. If you put the hard top on, you will gain back all of the weight of the soft top and motors (or so I have been told)
For amount of rubber you can run... I've heard of people getting as much as 265 up front and 295 in the back. You may need to slightly roll the fender for this, but it really depends on the offsets of your wheels.
On the shocks... No idea why they are so pricey. My guess is that the number of Boxster owners who want an improved suspension are probably less than 100. Given that there is very little demand for these products, it costs quite a bit for them to essentially custom make something for us. Again, that's just a guess.
Max. width for stock would be 8.5"F/10"R. Since the R6 tends to run fairly wide, I use 245/275. I know that I could shoehorn a 255 up front, no way a 285 will fit in the rear with my set-up. Damn spring perch gets in the way
Also, give Dave Bottom at Arlan Motorsports a call. He has worked on quite a few Boxsters out on the West Coast. He will have to send you some parts for the Motons.
Once all is sorted and I bend, push, and break all the rules I can possibly find I will determine which class it would run in. The likely answer is the one I do not want to hear but thats how it goes.
Lurker;
If you're in the Midwest, you might want to contact someone at Fred Bakers - he built one a year or so ago. You might also pick Eric Steinel's brain - I believe he currently maintains the car.
A guy named John williams runs his Freddy Baker prepared Boxster in NASA GTS2.
aeschultz, you are right, Steinel's does care for it now. Sorry I don't have any contact info for John. He's a nice guy and I am sure would help you anyway he could. I am sure Steinel's has his contact and credit card info
