G2X GRM RPM pickup
Has anyone used the GRM RPM pickup for their G2X system? Where did you pick up the rpm signal? I know it goes to the coil but my coil has a plastic covering and before I cut into it I wanted to know my best options here. How do I identify the right wire to clamp onto? Any insight out there?
Thanks,
Don
Thanks,
Don
I have RPM on my G2X ('86 911). I did not install it but I thought it went to the tach. It is also hard wired in.
Don't forget to change the setup for 6 cylinders to get accurate readings.
You can get this by splicing directly into the wire from the DME to the tach - no fiddling needed. If you go to trackvision (www.trackvision.net), member (and president) Tony Kelly has the wiring pinouts as to which wire to splice into. I'm a 944 guy, but I'm pretty sure that the 911 instructions are there as well.
check out this rpm pickup harness i was referring to, no cutting involved
http://www.g2xtreme.com/hardware/sensors.htm
Andy, that was the one I got...i got it fgured out tonight. I was making it much harder thanit really was...thanks guys for all of your thoughts.
Don
Don
There was a cover over the coil that was much easier to remove that I first thought. Once I had the cover off the wire was easily seen. Now all I have to do is drill a small hole through the rear firewall and back to the + coil wire and I am good to go. I am attaching a picture of the inside of my car where I have the display mounted up by the lower left of my windshield and the G2X box on the knee back on the passenger side.
Don
Don
Oops...I may have spoken too soon...although I saw what I thought was the right way to hook it up, after speaking with Tim at Racepak today I think I better go back and regroup. The GMR pickup will not work with my single coil setup.
Matt mentioned tapping into the wire from the DME to the tach. I could not find the pinout diagram on trrackvisions website and they directed me to G2X website. I could also tap into the tach but I am not sure how to get to the tachand getting to the DME relay would be much easier for me.
Has anyone done this on a 911? Mine is an 88.
Thanks for the help...
Don
Don
