More on Harness Rules
#76
Originally Posted by amaist
Why is having properly defined passing procedures nonsense?]
I'd like to see more drill type activities at DE because I've learned a lot from doing these things myself. For example, how about a "No Brakes" session? Or a "Drive on the left" session? If DE is really about education, then lets come up with ways to increase skills, rather than just on-line speed around the track.
Just because you personally may think that a particular passing side is comfortable for you doesn't mean you are making the right choice. Do you have over 10 hours at that track or are you there for your first ever day?
Do you really think it is a good idea to come to such an event?
How long does the Nurburgring manage to stay continuously open on public days? 45 minutes at a time? And then they have to scrape someone off the railing.
#77
Darren,
Having the passing side pre-defined does not equal mindlessly following the same line over and over. In my region (the same region as amaist), the passing rule is simply: the passing car should be given the inside to the next corner. This way, whenever there is a late pass, the passing car has the inside line which is a lot safer. But not only is it safer, but it forces the passing driver to use their vision skills to get through the corner properly since they are now off line, which is educational.
#78
Really...
There's not a lot of difference in the positions here.
The local Le Circuit PCA Region has been very careful in exactly who has progressed into their advanced groups for a long time. That has its bad points for sure, but it also has the effect of allowing a comfort level that is not present in many less perspicacious organizations. Their advanced group is as aggressive as any other you'd find. The difference is that the line is well known, understood, even courted, but rarely ever crossed. THAT is what seperates them from the pack.
Trackmasters is run much the same way, and you can be comfortable driving in very close proximity at a very high level.
Of course, most of them up'n'air have never driven any other track... but that's another thread.
There is also not a tremendous difference in a "good" vs- "bad" pca event, except for the amount of hard work it takes to get better. There's a lot to be said for getting better!
#79
Is this about me personally? Yes, it will be perfectly safe to pass me on either side on a track I've never been to on the first lap.
It was fun, I'll probably do it again. A little more aggressive than the Nurburgring, but not that different. If it's not a good idea for you, then you don't do it.
There are plenty of organizations in North America that don't treat you like a child once you prove you can drive at an appropriate level.
#80
Originally Posted by RedlineMan
Really...
