Once Super Blue, you can only use Super Blue?
I have one data point, but it is from the senior tech at one of my local dealerships. He stated that Super Blue brake fluid is good stuff, but once one puts it in, one can't go back to the yellow OEM fluid. He stated that the mix of the molecules in the Blue with the OEM fluid will destroy the braking system. Never heard this before. Any knowledge out there?
Never heard this wither but I am no Porsceh mechanic either. I use Super Blue but ATE also makes the same fluid in a gold color so that you can see whne the blue is flushed out.
Regards,
Steve
Documenter of Ineptitude
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Pegasus has a good chart of all the brake fluids that are compatible.
http://www.pegasusautoracing.com/gro...pID=BRAKEFLUID
RL Technical Advisor
We've been using both products interchangeably for 10+ years with no problems in hundreds of cars.
I can't speak to that issue, but can say that I changed from ATE Super Blue to Castrol SRF in my GT3 this past spring. I did a brake bleed last week, and the SRF fluid was blue! This surprised me as SRF is clear....
Is this normal. and if so, how long does the *dye* last in the system?
-B
-B
Super Moderator
Needs More Cowbell
Needs More Cowbell
Just use Castrol SRF and be done with it.
You'll never have to think about brake fluid again.
(yes, it's $70/bottle, but it's cheaper/easier than trying to explain to your dry cleaner about what really happened to your driving suit)
And BTW, I think your mechanic may have gotten confused as to the make up of ATE Blue....perhaps he thought it was DOT 5/silicone based?
Super Moderator
Needs More Cowbell
Needs More Cowbell
-B
-B
ATE Blue will more often than not leave a blue 'ring around the bowl' on plastic fluid resevoirs.
Originally Posted by ltc
Likely the entire system wasn't bled completely the first time. Clutch slave may not have been completely bled as well.
-B
Mr. Excitement
-B
-B
As others have already said there are no issues switching to the gold. It does take forever to get all the traces of blue out of the system, especially the abs.
