Transmission oil for 996 cup
that's not misinformation Geoff. if you want SHC then you need to buy the replacement Delvac. I never said you can't buy it here prior to being replaced. Remember, those lads across the pond get all kinds of stuff that we don't.
**I realize it is a relabel type of situation but as far as buying it, you can't buy SHC as it was labled**
Technical Guru
Originally Posted by jaholmes
I put in the Delvac stuff from Lufetnic...which I thought would work but that is where my problems started. I drained out the original factory fill. So then I went to the dealer to have them put in the Mobil1 they recommend and still the same problems.
Any idea what a rebuid would cost considering you can get a new /31 gearbox for $7,500.00.
Originally Posted by Geoffrey
Yes Kevin it 's me, Andy and I had a good time at Gingerman. I place 9th overall and 4th in class for the sprint and enduro. Not bad for my fisrt race in 13yrs and first race in the cup car. We are going to Putnam next weekend then Road America in Sept. Are you going to make Road America?
Originally Posted by kbc993
Thanks LVdell for the info, can you buy Mobil Delvac at Autozone, Pepboys etc?
I read through some of the 993 posts and it sounds like this is a common problem with the 2nd and 3rd gear synchros.
What I truely don't understand is how 10 year old transmission fluid from the factory can shift better then brand new fluid. Truely a mystery fill.
Gingerman was a blast. I finished 12th in both races. Not bad I guess for my 1st race in the Cup and 1st race of the season. It could have definitely been better though. I was 9th in the sprint at the half way point but couldn't hold anybody off as my tires seemed to go away quickly. I was running Yokohamas and the last 3rd of the race the car was a handfull. There rear end was all over the place.
Well, my trans rebuild is done, and I need to fill it with something. We have the same synchro parts as you have in your 915 units (in our 78-84 boxes for the 928) - I know they get finicky with temps, and need a certain slipperyness.
Should I break in with Swepco or start with a good (but not too slippery) synthetic?
Darth Cup
I think I will have to miss RA this year?
Darth Cup
Please switch to Michelins by the time of the RA race, Yokes will be scary in the Kink!
