Tool for spreading caliper pistons on 997S
Old 07-01-2007, 11:34 PM
ECS
ECS's Avatar
Default Tool for spreading caliper pistons on 997S
Finally got off my butt and am doing my own pad changes. Got burned at the track. I am planning on using a screwdriver with a large flat head for pressing the pistons back in order to get at the pad. Anyone with other suggestions?
Also, anyone have any gotcha's with this procedure? I am not going to redo the sensors but will put in the squeal discs. I'll tie back the sensor wires.
Old 07-02-2007, 12:06 AM
10 GT3
10 GT3's Avatar
Use the flathead against the backing plate of teh brake pads to compress the pistons works easiest.
Old 07-02-2007, 12:24 AM
911S3.6
911S3.6's Avatar
Eagleday makes a really nice pad retractor.
Old 07-02-2007, 07:29 AM
jerome951
jerome951's Avatar
I recently bought this and it works quite well:
http://www.lislecorp.com/tool_detail.cfm?detail=309
Think of a heavy-duty caulking gun. Costs ~$35.
Place the spreaders' plates against the top of the brake pad backing plates and just squeeze a couple times. Not sure it will work on your larger brakes.
Old 07-02-2007, 08:14 AM
Larry Herman
Basic Site Sponsor
Larry Herman's Avatar
That's fine for floating calipers, but not on 4/6 piston brakes.
I just use a set of channel locks (and a rag) to get the pad away from the face of the rotor. Then I use a heavy duty paint 1.5" wide paint scraper to work the pad back. No problems.
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Old 07-02-2007, 09:28 AM
Matt Romanowski
Rennlist Hoonigan
which cost no drachmas
Matt Romanowski's Avatar
Received 1,001 Likes on 598 Posts
Snap On makes a tool for holding pistons in while servicing calipers that works great for spreading pistons out. Check out http://buy1.snapon.com/catalog/item....re&dir=catalog
I've always wanted one of the tools that the pro teams have, but I've never been able to find it.
Old 07-02-2007, 09:37 AM
Toby Pennycuff
Toby Pennycuff's Avatar
Matt,
Do you mean this tool? I'm with you in terms of always wanting one of these. Just never could develop the moxie to go spend this amount of money on a pad spreader! Must be made of stainless steel! But, as we sometimes say here in the DFW area, "it shore is purdy!"
Toby
Old 07-02-2007, 09:59 AM
Veloce Raptor
Veloce Raptor's Avatar
Received 1,681 Likes on 869 Posts
I just use the pad I am removing from my 4 piston StopTech fronts to lever the pistons back into the caliper in order to receive the new pad. Works like a charm, and no extra tools required.
Old 07-02-2007, 10:30 AM
jakermc
jakermc's Avatar
Originally Posted by Toby Pennycuff
Matt,
Toby
I bought a nearly identical one from GiroDisc. It was a bit cheaper but still very expensive. After using the 'pry bar on an old pad' method for years, this is a pleasure to use. Downside is that its a bit large to take with you when traveling.
Old 07-02-2007, 10:32 AM
Veloce Raptor
Matt,
Toby
Gynecologists use that very same tool, I am told.
Old 07-02-2007, 10:58 AM
Matt Romanowski
Rennlist Hoonigan
That is the one! I won't be buying one with that price tag, but that's it.
Old 07-02-2007, 11:08 AM
mooty
GT3 player par excellence
mooty's Avatar
Received 5,802 Likes on 2,376 Posts
i have both the one in the link and the eagle day tool. both work, but eagle day is much much easier to use, however, it is also about $200 or so a pop.
Old 07-02-2007, 11:11 AM
mooty
mooty's Avatar
Matt,
Toby
i thought it was insane for the price, but i used one my friend had... i think it's like impact guns taking wheels off, once you use one, you will not go back.
especially when you have to change pads on track when the temp of the car, pads, rotor and weather are all high.
Old 07-02-2007, 02:13 PM
jerome951
jerome951's Avatar
Actually, Larry, it does work (and I don't have floating calipers).
Instead of hooking it onto the floating caliper pieces, you catch the top of the brake pad backing plates then it pushes them apart.
This is nice in that you get retraction of both pads without pushing on the caliper and you don't get the back & forth motion from retracting 1 side then the other (assuming you want to remove both pads at the same time).
Old 07-02-2007, 02:20 PM
Larry Herman
Basic Site Sponsor
Cool.
Quick Reply: Tool for spreading caliper pistons on 997S
