August Hot Laps @ Thunderhill!
#46
Originally Posted by Bonster
Jack . . . the record, last time I checked (and unfortunately witnessed, lol) was Justin Hall with a 2:07:5. David Macananey holds a similar record (but about a tenth off of Justin). This is over the top, not with the bypass. A fast time is anything under 2:14 or so. A WINNING time is about a 2:09. This was not always so . . . 'in the beginning', when SM was still 'innocent' and 'pure', a fast time was a 2:15. With advancements in legal (some probably no so legal, but I won't go there) intake side mods and pricey engines, folks have taken that fast time down by over seven seconds since the inception of the Spec Miata class back in about (?) 1999.
I'm just frustrated because when I started out, a 2:10 would have won me a race. Back then, I was still struggling with a 2:16. Now that I'm consistently turning 2:12s and the occasional 2:10 or so, it's no longer a winning time. Poop I tell you -- just poop! But it's no big . . . I have fun, and that's really all that I care about. The last thing I need is a cheesy plastic trophy collecting dust anyway. Lol.![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
Track itself is significantly faster than even a couple of years ago. Some of certainly is performance creep; but when it was OK to do 2:10 in something like a streetish RS America, 2:07 is where things fall today.
#47
Originally Posted by race911
Hey I've hardly gone quicker than 2:10 in my SM......and it's a pro built, pro champion car!
As far as top speed into 1, well the Radical isn't going to peel your face back on acceleration. We'll leave that to.......to...........to........Van' (?!?!?!?). A Van sighting! Which color IROC do you have, and did you see that little article in Excellence about the press day at Riverside?
Karen says hi!
Karen says hi!
Good ole T hill on the main straight... to be honest I don't even think I broke 150 at the end of the straight, if I did it was not much over
![](http://img.photobucket.com/albums/v600/ChevyThunder/The%20Cars%20I%20Race/th_442D3303.jpg)
![](http://img.photobucket.com/albums/v600/ChevyThunder/The%20Cars%20I%20Race/th_IMG_8440.jpg)
![](http://img.photobucket.com/albums/v600/ChevyThunder/The%20Cars%20I%20Race/th_442D1715.jpg)
#48
Moderator and 993 whisperer
Oh, sorry, Kim . . . I was kind of guessing at the exact time. I remember that day, though, still. David broke the record in qualifying, then Justin broke it later in the actual race. I at that point no longer felt bad about getting pounced on by those guys.
#49
You own Justin's former car, Ken? Wow. It doesn't surprise me that your performance in the SM is different than one of your Porsches. Wanna see a super slow 911 RS car? Eheh. Just hand me the keys. I'm sure I'll have the exact same problem going between a front engine and rear engine car. I'm pretty quick in my friend's Elise, though -- but that's a mid-engine. I suspect it'll take you a while to transfer your skills over to that SM. Go-karting will help.
So . . . hmmm . . . if Ken is driving his SM, you mean I finally have a chance to pass him? Whahahahaha.
#50
#51
Miatas, when properly prepared, run pretty fast in the turns. It's kinda like an e-ticket ride type of thing. The guys that made those track records were literally on rails the WHOLE TIME. I don't have the guts to do that. But keep in mind, cars like Justin runs (and Ken bought one of) are worth well over $20k in most cases. It's a case of the log book sells the car.
The fastest I've ever had my SM down the main straight was only 110 . . . I nearly lost my teeth that day (from the grinding). The way to make your entry into turn one starts way back at turn 12, actually. If you have a lot of speed going between 13-14, at least in a Miata, you can literally drift between 14-15 (I've not yet driven a Porsche, so not sure if drifting will work here). I don't know if that's the right way to do it, but it's been bringing my times down somehow. I don't typically suggest drifting, but in that particular set of turns, it has been working. Kim Ouye has way more expertise here -- hopefully he'll chime in.
