Converting a 911SC to an SCCA ITR
Can someone give me some advice on what to concentrate on in order of highest prioroty. Certainly Safety is number one but what about exhaust, tires, wheels, etc.
I want to stary with the minimum and over time continue with improvements
Beyond the safety stuff and basic durability concerns - wiring, engine status, etc - I'd recommend focusing on suspension... IT classes are primarily a suspension class, so as long as you've got solid running gear for drivetrain, you'll be OK for the first year or so, till you get used to the crowd - but if you lack in suspension, you'll be second-rate at best. At very least, I'd be wanting high spring rates, good dampers to go with, and good new bushings, be they spherical or just plastic (delrin etc) to keep costs down...
Best of luck...
Best of luck...
Contact Dan Jacobs and he can set you up with his fabulous G class setup.
http://www.hairydoggrrrage.com/
You are also allowed to remove the interior bits but that will not help much, I think it's best to keep it a legal PCA G class car then you can run in both PCA and SCCA competitively. Get rid of those heavy bumpers and add ballast if needed, in the passenger's footwell (or front trunk if legal in SCCA, not legal in PCA).
It should be close in speed to the ITS cars (Mazda RX7 etc) maybe faster on a high speed track so you should have some good racing even if there are still few ITR cars.
Have fun!!!
Have fun!!!
This is not a negative remark. I am curious why you want to build a SC for IT?
yup read BOTH rule books. Odd that SCCA allows removing interior and PCA allows replacing bumpers, but not vice-versa... so may be tough to make a car competitive in both. You could always run a PCA car in ITE, same group usually.
p.s. 74 911 bumpers (at least one of them) is lighter, nobody will know the difference
