Hoosier R6 Pressures?
Old 05-25-2007, 03:01 PM
Jim Clark
Jim Clark's Avatar
Question Hoosier R6 Pressures?
Looking for R6 “Cold” starting pressures
2600lb 944 on 245’s
Old 05-25-2007, 03:40 PM
Jim Clark
Jim Clark's Avatar
From all the posts in archive it seems 40lbs hot is the key.
Old 05-25-2007, 03:43 PM
Larry Herman
Basic Site Sponsor
Larry Herman's Avatar
Jim, I'd say start around 27~28 cold. Depending on your spring rates, camber, wheel widths, yada, yada, yada, you should be running between 34~38 lbs hot. Any more than that and they get greasy. My car works best at 35/37.
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Old 05-25-2007, 03:47 PM
Bull
Bull's Avatar
Same here as Larry. I find them best at 35psi on my 2600lb car. 40psi is not good.
Old 05-25-2007, 04:05 PM
Jason Judd
Jason Judd's Avatar
+1 with Larry,
I start out 26~28 psi cold...I also try to get to 35 psi hot for my 2,650 lbs 968.
Love 'em by the way.
Jason
Old 05-25-2007, 04:27 PM
AndyT
AndyT's Avatar
36 hot is the max for me on my heavy turbo. start at 27 all around
Old 05-25-2007, 04:43 PM
bgiere
bgiere's Avatar
I have been starting mine (245/40-15) at 25 cold. That has gotten me 34-36 hot and that has been best for my 944. Car weighs 2780 with me in it and 3/4 tank of fuel. I have turbo sways and Koni adjustables front and rear.
Old 05-25-2007, 06:16 PM
eclou
eclou's Avatar
Received 1,199 Likes on 586 Posts
I start out at 27-28 cold and up to 34 hot on my 944 turbo (2700 lbs). On my 997TT I tried at 27/29 F/R and it sucked - was only at 33-34 hot which was too low. Bumped up to 36-37 hot and was much happier
Old 05-25-2007, 06:21 PM
Jim Clark
Jim Clark's Avatar
Gives me a place to start, I appreciate all the information.................25-27 cold with 35ish hot.
Old 05-25-2007, 10:23 PM
93 FireHawk 968
93 FireHawk 968's Avatar
I drive a 3050lb Fire Hawk 968 and start the pressures at 28-29 cold. Hot is right about 38lbs. Anything more and the grip is compromised.
Old 05-25-2007, 10:55 PM
richard glickel.
richard glickel.'s Avatar
Ditto.
Old 05-26-2007, 09:30 AM
993inNC
993inNC's Avatar
You'll know when the pressures are correct (assuming all other adjustments are correct) when you see about 6 lbs of increase from cold pressures.
Old 05-26-2007, 09:36 AM
924RACR
924RACR's Avatar
+1 - my 2600lb 924 runs around 36 hot, which takes around 30psi cold (that 6-lb rise, as noted).
Old 05-26-2007, 10:21 AM
Larry Herman
Basic Site Sponsor
That does not hold true for my car. I get about an 8 lb increase in the front and a 10 lb increase in the back on an 80 degree day. It also depends on the track temp, as you need to start lower when the track is hotter.
Old 05-26-2007, 01:40 PM
Bull
Bull's Avatar
About 8F and 10R increase here too on a warm day.
Quick Reply: Hoosier R6 Pressures?
