What works best to remove rubber marks from DE events?
#31
<a href="http://www.sherwin-automotive.com/media/pds/5708.pdf" target="_blank">http://www.sherwin-automotive.com/media/pds/5708.pdf</a>
this MIGHT work. I'm going to try spraying it on the Kubota 1st and see how easy it is to remove.
#33
Arthur,
According to the description, Slime HS (what a name) appears to be the same as Supergreen Shield. It even has a green tint. It can probably be applied with a spray bottle as I described above.
Let me know how it worked out.
Good luck.
Mike
Good luck.
Mike
#34
I use a product from Honda called Spray Cleaner & Polish. A motorcycle shop will carry it.
Cleans and leaves a nice wax shine. Used it many years on my motorcycle and then discovered it works great on my track car!
