track issues... digital camcorder recommendations?
#91
thats another nice thing about the motorsports version. It comes with a waterproofed case that can be used underwater as well for other applications, that incorporates a glass lense to protect the camera.
mk
http://www.vimeo.com/907228
mk
Anyone running a chasecam digital recorder with a RaceCam lens? My trusty sony camcorder has lasted 5 seasons living in a protected padded bag but would like to stay ahead of the curve and have a back up ready. Chase cam recorder looks like a nice unit designed for our racing applications.
Thanks!
Thanks!
#92
#93
#94
they can mount almost anywhere, easily, and without the nasty vibrations that other mounts provide
check out "rear supension-cam"
with the proper motorsports mount, the noise issue went away. it sounds pretty good now.
Ill post a short highway clip at 100mph![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
mk
mk
#95
#96
SWA 911,
Nice video. Was this a "bone stock" Aiptek camcorder, or did you modify it in some way? It's hard to tell with the music, but it appeared to pick up the car sounds without too much wind noise. And was the IO Port mount clamped to your rollbar? I'm hoping to get a wider angle view so the driver's hands are visible; I'm not sure that's possible with this camera -- or with that mounting location.
Great tank-slapper spin caught on tape. Looks like that guy was lucky.
Rob
Rob
#97
Stock Aiptek with a small strip of masking tape over the mic. I just got it and had to make a quick mount at the track thus the location on the "A" pillar of the roll cage. When I get more time I'll mount it to the cross member of the cage. I think the mount location has a lot to do with wind noise. Where I had it mounted is a pretty calm area forward of the passenger window. Even the raw audio is very good with no wind noise at all. Once mounted in the middle of the car that might be a different story.
All in all I am very happy with it and the price was right. So much easier and faster to work with digital clips than going through the hassle of tapes. I was able to download each session to my laptop in just about 10 minutes between races.
#98
I'm still pretty impressed with the results the Aiptek produces. Despite the audio issues, its still a great solution for under $200. Can't beat that.
#99
The Penguin King
Another example from the Aiptek AHD.
I missed the apex... slightly. At least I wiped out that damn cone.
http://www.vimeo.com/895650
