track issues... digital camcorder recommendations?
#62
Does anyone have any experience with the JVC Everio GZ-HD7? It's a hybrid camcorder (can record onto SD and SDHC memory cards) that, according to a JVC customer support person, uses a similar hard drive to the non-high defintion camcorders that Bob and Tom have, except the hard drive is much bigger at 60GB. Because it uses a hard drive that Bob and Tom have had luck with in a track environment, it should not have any shutdown issues if one records to the SDHC card.
The Sony is a damn nice camera, but the JVC seems to be, too, and because it has a great manual focus ring (I use manual focus on autofocus cameras fairly frequently), it's been getting my attention. One of the downsides to the JVC is that the OIS (Optical Image Stabilization) is not that good at 10X or greater, but that should not be an issue in a car since the lens will be zoomed out to the widest angle. At least, that's what I'm hypothesizing
http://camcorder.jvc.com/product.jsp...Id=141&page=10
#63
The Penguin King
I just picked up an Aiptek camera (AHD 720p) for $138 at Circuit City....anxious to get it mounted up and taken to the track! It is a pretty cool toy for the money.
Let me know if you figure out how to tweak the audio. The mic is very easily overdriven based on the little testing I have done, I am going to try to put some things over the input to tone it down. If anyone figures out a more technical method of fixing the mic on this type of unit, please let me know.
#64
Needs to Get a Life
I recorded this yesterday. I had the Aiptek camera mounted to the rear window of my car using my Woods Power Grip camera mount. Both driver and passenger windows were wide open. Unfortunately, because of traffic, I couldn't get above around 70 mph. I had to jump through a couple of conversion hoops to get it on the web, so the video quality is compromised a bit. I've done a small mod to the camera, placing some felt on top of the microphone, and then some masking tape over the mic opening, both to diminish the wind noise.
http://www.vimeo.com/463288
I couple of more data points on the Aiptek. After reading this thread I went to Target today and picked on up. The A-HD 720P was on sale for $119.00. The box reads as follows:
HD Quality Video 1280 x 720 @ 30 FPS
8 megapixel Max photo resolution
Supports SD card up to 32GB SDHC
Night Shot for picture capture in low light
Includes: Strap, Lens Cap, USB Cable, AC Adapter, AV Cable, Compenent Cable, Li-ION Battery, Manual, CD
In HD mode it says it will record 240 minutes on a 8 GB card.
4x digital zoom
I needed a better camera for the car. I tried to get away with a cheap sony 8MM system and the camera was a cheap piece of crap (my fault for buying it). Hopefully, this will be better. I do not know much about video and photography. I am one of those customers who takes it home and plugs it in and does not appreciate all the functionality or technology that is in place.
Just another data point....
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
I will be trying it out this weekend at Homestead.
Lindsey
#65
The Penguin King
By request, I've taken a still shot with the Aiptek A-HD camera from the approximate location it would be placed if mounted to a cage/bar. The camera was 48" (+/- an inch or so) from the windshield in my 997S. This should give you an idea of the field of vision you get from the camera.
To answer another question I received, you can not use an external microphone on this camera unless you are also using an external video input as well and using the Aiptek as purely a recorder. If you plug a microphone into the camera, it assumes that video input is also coming in from the AV input, and you get not video. I have tried this.
Hope that helps folks out a bit.
#66
Hey Mike,
Is that still image taken from a video clip, or is it a still pic taken with the camera?
Asking because the aspect ratio is all wrong given we know the Aiptek produces 16:9 video frame size [shown in the test clip I posted earlier in this thread].
#67
The Penguin King
Still image taken in photo mode. Good catch, I didn't think of that.
#68
IPSC
#69
For those interested in improving the sound on the Aiptek camcorder, here are a couple of threads that discuss various mods, including how to add an external microphone:
http://forums.steves-digicams.com/fo...14&forum_id=92
http://forums.steves-digicams.com/fo...62&forum_id=92
#70
The Penguin King
Here is some video I shot at the track with the Aiptek A-HD camera this weekend. I have done some minor modifications to the camera to improve sound. Specifically, I've placed some felt under the microphone cover, and some masking tape on top of it to help deaden the wind noise. It helps quite a bit. The camera was mounted at the very lowest point on my rear window using a Woods suction mount. I zoomed in a bit to fill the screen with more track and less of the back of my seats. The video was converted to .avi with Quicktime Pro, then edited with Final Cut, and finally uploaded to Vimeo, which apparently does some downscaling. I'm going to try to figure out how to get Vimeo to display full HD.
http://www.vimeo.com/611741
Before you ask, I was running on a cold track & cold tires, & failed to take that into account on my entry speed. Stupid move. Once I got into turn one, I realized I wasn't going to make it, and decided to just drive off. You can see my hands turn to the right just as/before we go off. So at least I made a graceful exit.
#71
Mike,
Any chance you could post a clip without the background music? I'm most interested in the raw sound quality, and the music is drowning that out. Also, which windows did you have open? And was this the standard lens or a wide angle lens?
Thanks for your help.
Rob
Rob
#72
The Penguin King
Standard lens, both windows open. I'll have render another version without the music. I would consider the sound tolerable, but certainly not great. That's why I put the music on there (in addition to accentuating my droving off the track). It will take a day or two, but I'll get a low res one there for you with no music. I'll have one in true HD with music tomorrow morning. It's uploading right now.
#74
The Penguin King
Ok guys, here is the HD version. I still suspect vimeo is doing some compression. It looks more pixelated than I had hoped, but still not bad from a $120 camera I think.
http://www.vimeo.com/611950
#75
The Penguin King
OK, one more version. By request, an HD version without the music so you can hear what the sound "quality" is like. Not great, but not too bad as far as I'm concerned. I used a different setting on Final Cut to output this file.
http://www.vimeo.com/613813
It would be nice if we had a way to embed vimeo videos like we can for youtube.
