Hoosier R6 Tire pressures
GT3 Track Junkie
1 Post
Im running Hoosier R6s for the first time, does anyone have the correct cold and hot pressures I should be running? Im driving a GT3.
Cold, start low 30's, I found 40/42 range hot. You will need to pit 2/3 times on hot tires to adjust. Drive the tires hard and come in hot. They did not get greasy as the 05's normally do.
Basic Site Sponsor
Basic Site Sponsor
I was running lower pressures for my car. Hot pressures were 37 front and 39 rear. The grip was terrific and they never felt greasy, even after an hour in the enduro. I set my fastest time on lap 20 which equates to around the 43 minute mark at the Glen.
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Larry Herman
Past Flames:
2004 GT3 Track Car
Originally Posted by DJF1
what sizes do you run bob?
I have run 245/35 fr, 285 rear, then changed to 245/35 fr, 295/35 rear which was good, new config: 245/40 fr, 295/35 rear. The 245/40 is MUCH wider than the 245/35, but is the proper height. 295's fit no problem, but will rub without monoball bushings.
Braking on the 245/40 is significantly better than any other tire I have run. My car is a pig, stock D no ballast 3041 lbs. Camber 2.1 rear (better wear on the inside), 3 deg up front.
Basic Site Sponsor
Basic Site Sponsor
Originally Posted by Jerseybean
Dont they recommend setting the cold pressure by car, fuel & driver weight?
Thanks Bob, I take it you see better wear with the R06 than the previous model especially since the 295 has a better load rating than the 285.
