Need advise on quick disconnect for steering wheel
Anyone have a part number for the Porsche Q/R? I would be interested in seeing what Sunset would sell it for since they seem to be by far the cheapest on other Porsche parts.
Originally Posted by RedlineMan
Don't underestimate the handiness of an indexed release. Trying to figure out where straight is is needless hassle.
I just used a paint pen to line the two pieces up. Not a hassle at all. But you have to make sure you get it clicked all the way in. I had the wheel in my hands at speed on the front straight of Mid Ohio, once...
Originally Posted by Geoffrey
Yep, Phoebe. However, for the 964 I had to cut the Momo hub adapter and machine a spacer because the reach was too close with the momo adapter, even the shorter one.
Not a track car per se, but I have an SPW QR that I like.
SPW Quick Release link
With the Momo adapter and the SPW quick release there is no need for a dished wheel or spacer.
Bro
Originally Posted by Premier Motorsp
The Porsche Q/R is about $400 and worth it.
All the ones that are splined or hex are strictly for show, no place for them in any car.
The Motorsport quick release is designed to be used with the same 6 bolt mounting arrangement that a Momo steering hub adapter has. The long hub adapter (from splines to 6 bolt mounting) is about 3" long and the short is about 2" long. Your 964 Cup car has a Momo steering wheel, or I should say that it came from the factory with a Momo steering wheel and hub adapter. If you use a seat with a halo, then you'll need to remove the steering wheel for ingress/egress on the driver's side. Using both the hub adapter and the quick release puts the steering wheel in a NASCAR position where, for me, at average height/weight it was too close. I cut the Momo adapter and machined a small 1/2" spacer/adapter to move the steering wheel farther away.
The Snap Off isn't bad, no play. BUT, it requires two hand operation. That means it is impossible for anyone but the driver to operate it in a hurry.
Chris Cervelli
Premier Motorsports
Chris Cervelli
Premier Motorsports
