cage questions for DE car, possible club racer in near future
#106
Originally Posted by kurt M
Was this the flat X? If so there is little change over the non reinforced model. If not then
we got some head scratching for sure. Was this a single plate reinforcment? I wonder what a Taco type install would modle like. I would expect it to move the strain and its result of out to the ends of the tacos. End up with a truncated cone shape.
Bro
#107
I agree that distributed load is basicly a waste of time. In a front end crash bars from crush zone and suspension pickup points will transfer to points.
One thing I think you might be missing in your model is bottom box beam? (see photo) At least in my 75 911S tub this is a massive if fairly thin walled structure.
It is interesting that the gussets didn't change the deflection at all but I would think their main purpose is to strengthen the welded tube junction, not stiffen it in a the broadside direction. They probably help stiffen the structure torsionally too.
Should be intesresting to see how the Nascar bars fare, I'm guessing they will deflect more than either of the X designs since they are bent at the ends and the load won't have a direct path to the other bars.
#109
Cool. I'd be really interested in seeing the pyramind X results from the same impact. That will be an interesting comparison.
It's also rather interesting that even with the offset impact, the greatest deflection is still the center of the X.
#110
Originally Posted by Geo
I would also run the scenarios with a relatively small load distribution at an angle for the different cages. What this would represent is in an angled crash the corner of a car would be what would contact the structure. Also, try this with the impact being off-center of the X.
#111
Pyramid with central angled impact
Pyramid with offset angled impact
#112
Bro...kudos to you for all the runs. You're doing great stuff here.
All...gussets are primarily used to distrubute loads over a greater area to delay (or prevent) the onset of a failure which would generally be a cracked of severed tube for this application. Most often you'll find the maximum stress(es) to occur at the intersection of tubes...enter Mr. Gusset. As Bro mentioned, the stresses in some areas are way way past the point of yielding. This stucture will now have a permanent set once the load is removed.
Notice the double ended arrows at the ends of the vertical tubes in the side impact cases? These locations are not allowed to move. Do you believe this is so? Pretty decent choice at the bottom (sill). But how about at the top? Pretty good, but only if the front and back tubes are tied into the car...which most often they are not. Once Geo or somebody gets Bro some full cage geometry, Bro be turning this excellent simplified design study into some extraordinary.
Ok, how about this situation. ..non-tied in cage...side impact. How do flat vs. pryamidal or bowed out X compare?
Flat X...side impact...verticals at the top get drawn toward each other...severe tensile loads/stresses in the X at top tie in points...X has the ability to head further toward the driver. Thus, an "impoded" look per John H. If the deflection is sufficiently large, this is not desired. Improvement opportunity...add horizontal bar to top of the X...hope the collision fundementally remains below this...plus live with aggravated normal entry/egress.
Pyramidal or bowed out X....verticals at or get pushed away from each other...severe compressive loads/stresses in the X at top tie in points...X has the ability to head further toward the driver. If sufficiently large delection, this isn't desired. But, this deflection has to be much greater with the space created with bowed out door bars. Improvement opportunity...add a bar stop tightly fit to the front and rear verticals so the load goes immediately into the chassis...bar stops only are practical if you have a real tight fitting custom cage...kind of fussy and hello more $$$.
I'm coming to the general (partial) conclusion that for sufficiently severe applications, tight fitted to body cages judiciously tied into a car having a fundmentally stiff body/chassis can provide some meaningful advantages.
Foofd for thought and comment....you really want to create sufficiently low G-loads on the driver or occupant. Brick S*%$ House designs that don't mitigate the impact G-loads are not the answer. And obviously highly deformable designs where tubes enter the driver or occupant space are no good either. We all strive to dance somewhere in the middle...but where??? I say welcome to experience (John H., Tinman, Joe, Geo et als) and engineering (Bro, Sunday Driver, et als) as this is an unbeatable combo.
On a related note. My gut tells me a tremendous opportunity exists (to lower the driver experienced G-loads) between the cage and the H&N system....the seat! Whether that be the method of suspension and/or mini torso and head air bags. Get to it you entrepreneurs and engineers!
Mike
Mike
#113
Bro, this is some awesome stuff. Your data clearly shows my assumptions were not correct. Good to know, although with the main hoop set back from the door opening in my car, there was no way for me to do a pyramid anyway. But this is great. The NASCAR bars should be interesting as well.
If I can get over to the shop tomorrow, I'll get you all the dimensions to use to construct a cage.
#114
You guys are easily amused.
Thanks for the praise, it really isn't that difficult, just time consuming. And time is a commodity that most of you don't have ( and I wish I didn't).
Gonna give some cerebral CPU time to energy absorbtion.
Bro
Bro
#116
Cory: I agree definitely more than half do not tie in. Only GT can legally. Rollover and side impact crush is the biggest threat and what you guys are modeling side impact on a concentrated point (6-12”) at different angles is definitely the biggest threat to the driver.
I see what you mean RE the bottom bar under the X replaces the sill for modeling.
I think for NASCAR model you should have 3 bars (arched) and 1 sill (strait) I believe this is the “true” NASCAR setup (see photo). The big advantage to NASCAR in my mind is surface area of protection. The both arched X and NASCAR give great crush protection. But the open area over the X makes me nervous. The reason I like NASCAR is it helps keep Sh….. out of the car. The local circle track guys even tack squares of sheet metal over the square openings in their NASCAR setups. The run very thin plastic body work.
HI Bro:
RE being easily amused. (don’t take this the wrong way your postings are great stuff!!)
If you really looking of a challenge: I’ll get you the dimensions and tube info on the nose of my car. A frontal impact simulation on that would be a pretty far out project and keep your electrons humming for a while!
HI Bro:
#118
HI Bro:
HI Bro:
Bro
#119
Are you ready to rumble?!!!
Here's the NASCAR bar analysis:
Wide loading
Narrow loading
I'm now taking requests for additional loading/design modifications.
Bro
Wide loading
Narrow loading
Bro
#120
Bro,
Can you summarize a bit.
For example a chart with following
...................Flat X..........Pyramid X........NASCAR
Pure Side....
Angle Side...
Pure Side....
Angle Side...
