quick MPSC question
will 265/35-18 wide MPSCs fit on an 18x8.5" rim? tire rack recommends 9-10.5" widths for the 265 but i am wondering if i could squeeze one on.
tia
tia
Michelin also recommends 9-10.5 (http://www.michelinman.com/assets/pd...tsportcup.pdf). FWIW, I have a 255/40-17 MPSC on a 9.5" wheel. I don't think you'll be getting more rubber on the road, er, track, with this wide a tire on that wheel. I assume this is for the front? I use a 225/24-17 on an 8" wheel for the front.
yes this will be for the front. just looking at my options. currently i am using 235/295 on 18x8.5/11. thinking about doing 265/315. the 295s look quite stretched and don't seem to be a true 295.
Originally Posted by 38D
It will be impossible to get 265s up to temp in the front. Stick with the 235s.
good point. even with my "heavy" car? ~3000 lbs
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
GT3 player par excellence
the narrowest wheels i wiould bother trying wiht 265's are 9"
i run 235 on 8.5"
i run 235 on 8.5"
Originally Posted by bobt993
I have seen 265's on the front of a 996 C2 , 2002. Also on a pro racing C class 99, 996 bought to run in PCA(just wrong). Both cars seems to handle great and I know both drivers are winning races with this set up. IM Darren for more info on what has worked on his 996. I think he has tried every tire combo, but settled on 265's up front. As far as temps. I did help him run temp/tire pressure readings with a pyrometer and did not see a huge disparity front to rear, but I will say on a hot DE session I was able to pull on him and check out early on the warm up laps running Hoosiers on my 993. ![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
i would love to try hoosiers and probably will eventually but my wallet cannot take it. 8~12 heat cycles then they are done right?
i run 235 on 8.5"
i run 235 on 8.5"
295 rears are matched with 235 but how about 315/235?
_________
are you talking about your car of my GT3?
on the GT3, the way i had it set up if i ran 315 in the back wiht 235 front, i get lot of push.
_________
Carlos,
Your suspension is severely compromised by the fact that you have to drive your car to the events. Take this away and you can dial in the negative camber that you need to help decrease the low speed understeer that you are experiencing.
...the way i had it set up if i ran 315 in the back wiht 235 front, i get lot of push.
that's what i thought.
Originally Posted by earlyapex
Carlos,
gotta make do with what i have
Dude, see you at the track!
Doing Laguna Seca on the 30th?
