DE tech inspections question
Is a person that does 10 events in a season expected to get 10 tech inspections, one for each event?
Also, what if 2 of the events run back to back? (One event Monday/Tuesday and another Wednesday/Thursday.)
In short...yes. Most tech inspection forms specify that the inspection must be done 2 weeks prior to the event. So, in your example, I would expect that your shop would sign 2 tech forms, one for the organizers for the event on Monday/Tuesday, and one for the organizers for the event on Wednesday/Thursday.
IMHO, you shouldn't have one inspection covering two events and two forms.
That said, I've done as you state. I just made sure to really look my car over between events.
Depends on the organization running the events.
It's not a hassle. It's a good way to help keep you safe.
The answer is "yes". Several times a year I'll go through tech on a Friday morning, run the event, then turn right around and go through tech again that evening for a Saturday/Sunday event. It does not bother me at all.
It sure would bother me if I was at Watkins Glen (5 hour drive one way) and I had to do that!!
Yes, I'm not referring to the final tech inspection at the track. I'm referring to the one that is supposed to be completed prior to arriving at the track.
yes, one pre-event inspection form per event. Whenever I do two events back to back, I get both forms at the same time. When doing multiple events in a row, it's a good idea to give the car a good look yourself after the first event, and bring a spare set or brakepads.
Originally Posted by shiners780
Yeah, I'm not talking about the final tech inspection at the track. I'm talking about the one that is supposed to be completed prior to arriving at the track.
Last year, NNJR ran two events back to back (Lime Rock Thursday/Friday, Pocono Saturday/Sunday). Since it was impossible for those attending both events to get a tech inspection done between events, we (the tech chairs) had a special tech sticker for the 'dual event' cars. At the morning track side techs, these cars were looked over more closely. Was it as good as a pre-event tech? No. But we did our best to ensure the cars were safe. AFAIK, there were no mechanical-related issues at either event.
The pre-event techs are vital to ensure your car is mechanically sound.
-Z-man, former NNJR track tech co-chair.
You shouldn't be charged for the tech inspection...you may think it's a bit too much, but you need a tech inspection done at a qualified shop for each and every track event. Then at the track itself a final tech is required.
During and after each track event the car should be looked over by a professional...there is no substitute for safety...we're worth it, aren't you?
1. Take your car to an NNJR-PCA authorized shop where they will most likely charge you around an hour's worth of labor.
2. Bring your car to the free NNJR sponsored pre-event tech - we have a crew of trained tech inspectors, and we asks the various independant shops if we can use their facilities after hours on a given day (2 weeks prior to the event) and we check out the cars. Along with the inspection there is snacks and drinks, as welll as plenty of bench racing!
I know some other regions have this type of setup, but sadly, less and less regions offer option #2 for their drivers.
-Z.
Originally Posted by Z-man
FYI: In my region (NNJR) you have two choices regarding tech inspections:
-Z.
-Z.
I don't know about you but I don't particularly like working for nothing, and if I do I think it should be my choice. To suggess that a mechanic should do your tech inspections for nothing is pretty bold.
Then on the other, hand mine does.
