wanna know what a 997 cup car makes on the dyno?
#31
Originally Posted by Larry Herman
Leh, I agree about the dyno. Chris's (Rockitman) car is a street GT3 with the europipe exhaust system. Mine was dyno'd with straight pipes & made 15 hp more than Chris's car. If his was making stock or a little more, then mine is quite strong.
Still, I would expect that a cup car has a bit more than that.
yeah these motors love hi flowing exhuast... or just strate pipes
#32
Originally Posted by mark kibort
Kingleh, why dont you tell us about the speed world challenge engine in the cup car power! and then let us drool over the dyno run of the 996GT3R without the restrictors!!!
amazing!!!!
Hey Brian,
what are the stock 996 for Grand AM cup GS running now as far as hp?
MK
amazing!!!!
Hey Brian,
MK
ok man your freeking me out.... im uploading dyno graphs of the 997 Vrs a GT3 RS without restrictors right now... plus almost compaired a world challange motor in a cup car Vrs the 997 also.. but didnt do that one...
#33
#34
also.. chek out that first graph done with mph...... pull was done in 4th gear and at 8300rpms fuel cut hit... rear tires moving 109mph... in 4th.... hmmm i smell short gears...!
#35
Not a clue Mark. Maybe Adam or Cory from Autometrics will chime in, or Leh if he knows. I don't even know if they dyno'd the '05 3.6L that we put in halfway through last season after we got it into the car.
I will say the '05 3.6L we put in felt substantially stronger than the 40k mile 3.4L we took out even carrying an extra 50 lbs of ballast at Barber.
Brian Bailey
Autometrics Motorsports Porsche 996 - Grand-Am Cup #45
'87 Porsche 944 Turbo - PCA GT3s
Brian Bailey
#36
Thanks Leh, Ive heard and now we SEE!!
funny, all that V8 talk about flat torque curves. that cup car curve looks like a table. doesnt get much better than that! (except more!!)
be interesting to see the GS Grand Am cup 996 dynos. I bet they got to be in the 300 rear wheel hp range.
Mk
Mk
#41
Wow that 997 GT3 cup sure is strong up top! As I guessed, it's no better (actually worse) than the 996 below 7K. The 6100 RPM torque dip is still there, even worse. I wonder how they got the top end stronger, better exhaust? Mine gets too lean at higher RPMS, tried a few tweeks on the dyno but the ECU leaned it back out... I guess it's a spec car so will have to live with it.
#42
Originally Posted by MJR911
Leh, whos shop is that?
#43
My car is early,(short rod) non gutted cats, early exhaust and no crankcase vent valve. When we run the gutted cats it climbs to about 344 rwhp from the 335. With the center exit late exhaust it is around 345. When You do the crankcase vent on an early car it is good for another 5-8 hp. Those are very real adjusted figures with no fluff at all in them. Same scenario the 03-05 long rod motor puts out about 360 rwhp. The 00 was rated at 360 at the crank and the 03-05 was 390 rated at the crank. Looking at a 15% driveline loss and You can see the factory is a bit conservative on their ratings.
#44
Glen, how have you been?
What are the torque numbers for 03-05 Cups?
While we're on torque numbers, what are they for the 3RS?
What's the weight difference between the 3RS, 996Cup, and the 997 Cup?
#45
Former Vendor
The GT3 Cup has been right around 255-260 ftlbs at the wheels since '02. Torque peaks later on the later cars, thus the increased hp.
996 and 997 Cup (without PCCB) have published weight of 1150kg (2533 lbs) dry. PCCB is good for another 45lbs.
An RS will be around 2450 lbs.
