HANS - Installation Pics - Opinions
#31
Originally Posted by mitch236
I don't mean to argue but do you have the data to support that?
Among SFI certified designs we are aware of several rumors and one well documented case of a HANS driver having died of head injuries when the belts slipped off.
There is more information out there, of course, but this is what we are aware of.
#32
Originally Posted by gbaker
Of the pool of non-SFI certified designs the worst injuries are three cervical spine fractures, only one of which required surgical intervention. These involved the Hutchens device, which has also had some problems with testicular injuries. We are not aware of any fatalities among non-SFI certified designs.
I agree that we need more information but I don't see headrestraint.org as doing that. Money is needed to test these devices properly and that money will come from professional racing. For me, the fact that what I see in F1 and NASCAR is HANS means alot. Maybe other forms of H&N will start showing up in the pro ranks. Maybe the professionals will form the committie that does the testing. But until there is more scientific data to determine which devices work and how well they work, my head will be restrained by the device that the pros use.
#33
We don't know, and we don't care. We already know what the results will be if tested. Besides, if you want to really test it you should test the entire assembly on a crash sled, as we have done repeatedly.
John's point is that rules/laws/regulations are always retrospective, so when something new comes along it's probably in violation of one rule or another and will remain so until the rules are changed. Our objective is maximum safety. If maximum safety breaks a safety rule, the rule should be changed.
This is what you are seeing with SFI 38.1. It's not a bad start, but as written it is dangerous. More drivers have died of head injuries while using SFI certified H&N restraints than non-SFI certified restraints. This trend will continue until the body count becomes so high it cannot be ignored by sanctioning bodies which, finally, are starting to get it.
#34
What we need to do as drivers, is to form a union and force the certifying community to set up a scientific, unbiased committie to assess these devices.
While Gregg was helpful in setting this up, it came as a result of drivers dissatisfied with SFI AND it is independent. Gregg is just supporting this effort because it's worthwhile.
#35
So your statistics are based on one fatality in total? And that fatality was documented as being attributed to the belts slipping off which raises the question about whether it was properly installed. Even if the death was attributed to a failure of the device (and not the installation), one death is not statistically significant.
What would be very cool is if headrestraint.org could grow to the point of being the important certifying organization like Snell is with helmets. The major problem with SFI is that it's a company by and for the manufacturers. It is NOT independent.
#36
#37
Originally Posted by Geo
Gregg, you missed my point...
"Gee, I don't know guys. Sure, it burns bright, doesn't smoke, never has to be refilled and can't cause a fire, but it doesn't meet the specs laid down by the kerosene lamp committee." - Thomas Edison (Just kidding.)
#38
Originally Posted by ltc
Agreed.
I was merely trying to point out some of the flawed logic behind the current 'rules' regarding certification and H&N restraints, many of which led M578 to purchase a 'certified' (and I still think SFI is a joke) personal safety device (HANS) vs. a non certified safety device (ISAAC) and then invalidate/modify a different safety device (helmet) because of it.
The reason I got the HANS instead is due to the SFI. Sadly for the forseeable future my main Sanctioning body is tied to SFI. It is very likely that by some time next year they will requiring a H&N Device. They have told me in very legal type terms that the H&N device will need to be SFI38.1 approved. Why?
Well to prevent "homemade" devices. Now I don't consider ISAAC to be homemade, but once everyone is required to have something then some cheap idiots WILL try to make a H&N device at home and most likely is a POS.
It just is the way people do things. So it seems clear that there MUST be some recognized standard that these devices must meet.
So the SFI comes along with the 38.1 spec. Nice idea, but clearly it is a flawed spec. So a device that passes the 38.1 is not perfect, but a very good device should pass it. The notable exception is the ISAAC. This of course has nothing to do with test results, but other things. It is similar to the rules staying your lights must be kerosene powered. Yep leaves no room for the electric light bulb.
Now with all this floating around you would think the clear solution is for ISAAC to push like mad on the SFI to adjust their spec or to revise the ISAAC. This were I have been waiting for months. I have been hoping to see some evidence that the original ISAAC might by SFI certed or that revised version is created. Sadly I have not seen sufficent evidence to convince me and have been seeing more and more telling me to get SOMETHING sooner rather that later.
So... while can wait around for the SFI ISAAC or hope my org does not require SFI cert all for the ISAAC, I can also just buy the HANS and be done with it.
Sure it may be more of a pain to install, wear, and even get out of the car, but while it may not be "perfect" there is enough use of it to show that it a very good device and just may save my neck in crash.
I still think this ISAAC vs HANS thing is similar to VHS vs Beta in the early 80's.
Everything we hear says Beta was simply a better system. However VHS for what ever reason won out. If you have a Beta VCR it is now just a nice archive piece. Sadly unless the ISAAC gets SFI certed I think it will go the way of Beta. May be better, but if you have no place to use it...
BTW... NO it is not FAIR nor RIGHT or ISAAC to get the SFI shaft. However there are plenty of things in this world that are not FAIR.
#39
I believe it will go the way of Snell, i.e. completely separate from SFI, probably via something like headrestraint.org.
Do you know that SFI certifies helmets? Do you care? Does your sanctioning body care? Of course not. Markets resist monopolies. Nothing good comes of them.
#40
So let me understand something. I thought that it was a money issue for the ISAAC to get certified, something like 10K to do the test? Is this the issue or SFI simply refuses to test it? If its the later why is it so?
#41
Danny,
It has nothing to do with money. In fact, we've already paid for and passed the "SFI" test--with flying colors I might add. Probably set a world's record in head load reduction.
We've been written out of the spec.
The specs are written to support SFI member manufacturers. HANS is a member and we are not.
#42
Super Moderator
Needs More Cowbell
Needs More Cowbell
Danny,
#43
Danny,
I know I'm missing a lot here and yes I know about the #800 gorilla
#44
Originally Posted by DJF1
Pardon me for my ignorance and thank you for the answer. Can you please elaborate on the fact that you were written out of spec? In what way? What is out of spec on the ISAAC????...
While presented as a "safety" issue regarding emergency egress, it is actually an old wives tale left over from the last millennium. We decided against this years ago. The fact is that the only H&N restraints that have ever trapped drivers in cars are those that meet Section 2.5.
(We have done extensive testing on this subject over the past year. The results will be available soon.)
This is the only reason Isaac systems are not SFI certified. It has nothing to do with crash sled performance, where, BTW, we kick massive quantities of posterior.
