Death at Lime Rock
#46
The below are more information reprint from this web site without permission from author.
http://p081.ezboard.com/fdsrforumgen...cID=1417.topic
Guys-
I'm the taller of Adam's two crew guys, Josh. I can tell you that he had his HANS on, his belts were tight when he left the pits after replacing a flat on lap 3, and the rest of his safety gear was on and in proper working order.
There was an error in the paper. He didn't hit the back of the Acura. The flagger from Sta. 7 swears he did, but the back of the Acura spun into the guard rail. The smash marks in the back of the tin top actually have the contour of the arm-co in it. Adam hit the front right corner of the Integra, and this I'm sure of because of the large amount of carbon and fiberglass body pieces stuck in the wheel, the pieces of bodywork embedded in the tire of the other car, and the piece of the front crash box/splitter that was stuck into the suspension pieces of the other vehicle.
It did happen on the uphill right hander, and the Integra spun about 3-5 secs before he turned in, which gave less than .75 sec for any evasive manuvering by the time he would have seen the car.
I can tell you all that he will be sorely missed.
Guys-
#48
Originally Posted by 84_Carrera
Everything else (except for the actual bridge abutment) has plenty of runoff room at that track.
#49
Originally Posted by 38D
Not even close to true. You can wad up a car basically anywhere at Lime Rock.
#50
Isn't there room thru the esses to run-off? Also, a few years ago I had a spin off the track halfway thru big bend with plenty of room in the grass. Of course if you are in heavy traffic it becomes a whole 'nother problem.
#51
Big Bend depends on where you go off and how fast you are going. I have seen many cars pulled from the tire wall on the inside. When it comes to the esses, I'll let 38D respond....maybe he will describe what they look like upside-down!
#52
#54
Legacy Flounder
Sorry, I compare runoff vs. WG's inside & outside barriers I guess. ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Seriously though, I've lost it coming out of BB at LRP, inside / outside through there, & the wife lost it once on the downhill & never hit anything solid.
#55
Condolences to the family and friends. Not to be morbid but we read thee threads to not only reflect but learn what not to do. If HANS was worn and safety gear intact what caused the death? Was this an issue of the danger of mismatched size/weights of cars? Did The SR3 drive under the Acura thus causing major body trauma? The Sr3 uses slopped side bars with no front hoop. The bars are not particularly substantial except perhaps against another Sport racer.
#56
One of the article said he had severed several arteries near his head...
Would a H&N help this?
http://www.zwire.com/site/news.cfm?n...id=12530&rfi=6
#57
#58
Oof, from the public relations manager of LRP. Is this good PR?
""There’s a whole slew of factors involved at a race track, many more dangers," Hasty said. "There’s many more variables than the open road.""
#60
The Rebel
This is always tragic and sad. My thoughts and prayers are with his family. Safety should always be the number 1 priority although it hardly ever is. Safety also begins at the organizers and track levels. Where there waving yellows??
