Proper gear shifting
#32
Basic Site Sponsor
Basic Site Sponsor
John, love the new Avatar, but don't agree on double clutching (or double de-clutching?). If you do it fast enough, you will match engine and wheel speed just fine. It does, however, take a lot of practice, and is not easily accomplished. So maybe your advice is better for the masses.
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Larry Herman
Past Flames:
2004 GT3 Track Car
#33
Agreed Larry;
...On everything you said. D/D DOES work. It DOES take practice. It WOULD be better for novices (novi?) to learn single H&T. It also is unecessary unless you have a transmission problem, or you're driving vintage iron.
In the end, it is hard enough to learn the timing for one go through the sequence.
#34
Larry, in your earlier post you mentioned that you still double clutch. Can you describe the sequence? Just wondering if you blib a second time, after you have shifted to the intended gear?
Cheers,
Cheers,
#35
Basic Site Sponsor
Basic Site Sponsor
Originally Posted by kwoksrus
Hi, I shift in the following manner:
brake, clutch in, shift to neutral, clutch out, blip throttle, clutch in, shift to correct gear, (clutch out!) throttle away.
#36
Thanks for that Larry. At least I have not been doing it wrong all these years. But as John quite rightly pointed out, sometimes I can let the rev drops too much before clutching out. John's single clutch technique seem to be smoother in rev matching, but I feel uneasy staying in clutch whilst I blip the throttle. Just a habit thing I guess. Still, I will give it a go and see.
Stanley
Stanley
#37
Hey Stanley;
What you have to realize is that the procedure I am talking about is over within a fraction of a second. Think of simply slapping the clutch down and back up. That is as long as it takes. If you couldn't hear the muffler, or see the physical motions, you probably wouldn't even know it hapened most of the time. Watch the "Lap of VIR" posted recently in this forum.
https://rennlist.com/forums/racing-and-drivers-education-forum/159123-in-car-from-vir-gt3-cupcar.html
That is how a H&T shift is done
#38
Basic Site Sponsor
Basic Site Sponsor
To echo John, the important thing here is to get the revs matched and to get the downshift done quickly. There is no one right way, and you should do what works for you. My way is more complicated, but it was something I learned on British cars, which had to be driven that way, and I have been doing it for 30 some years.
#39
I might be asking for some disagreement here, but in my experience, there is enough drag in the clutch that blipping the throttle as Larry says--to 6,000 RPM and catching the gear on the way down, does spool up the input shaft speed enough to reduce the synchro effort by half or more. Try it.
Oh and on a 915, the synchros don't wear much, it's usually the operating sleeves that do. The most expensive part, naturally. If you see the two parts together and compare the void ratio ( lots of metal machined off the operating sleeve, comparatively little from the steel synchro, you'll immediately understand why.
