987.2 S Mostly Track Car: Ohlins R&T vs KWv3
Getting ready to pull the trigger on new suspension for my 2010 Cayman S and found a few threads asking a similar question, but they are all quite old so I figured I'd seek any new opinions.
For some background, I drive the car 1-2x per week just to keep the fluids moving and battery happy, drive it 2.5 hours each way to the track (Sebring) and do probably 15-20 track days a year. Both my wife and I drive the car on the track, so it gets 4-5 hours of track time per day. I'm a fairly skilled driver, have had pro coaching, etc, but in recent years have dialed back from driving 10/10ths and focused on every 1/2 second to drive 9/10ths and just have fun (so from mid/high 2:2X at Sebring to low 2:3X for those that the reference makes sense). My wife just recently went solo, so she's in the high 2:4X and getting faster all the time.
Plan on doing sway bars, end links, LCAs, etc. while the car is in pieces already. I'm leaning towards KW mostly for the linear springs as I had those on my last track car and preferred that feel, but just looking for any real-world feedback from HPDE junkies that have experience with either/both?
I have the same car and went with the Ohlins and have been extremely pleased. Ohlins have linear springs. You might have seen my car it is Black #61 and I run NASA TT3 and Chin red group.
Peter
Peter
Spec cayman is moving to a new shock this year. Keep your eye's peeled and there should be some good deals on used JRZ RS coming up. They are great shocks, and perfect for your use case.
PTSFX (01-06-2022)
It’s still a single adjustable JRZ shock. They are switching from a double-tube design to a single tube design and strengthening the housing and bolts. The single-tube design is slightly better suited for track, over street since it operates better in a narrow travel range, which you will get with the track springs. The compression is fixed, already dialed in for the 987. Compression tends to be something teams figure out for the car and then set anyway, adjusting rebound for different environments. you can still buy the older shocks I believe, and the new versions won’t be available to non-racers for a little bit.
I know you have a .2 but the Spec Cayman package (shocks, springs, bars, arms, links) is really well set up! The SPC cars hold their own in club racing 😀. It might be a bit too rough for street driving (dial back that rebound), but with the amount of track events you both attend, it’s nice to get a whole setup that just works, rather than getting different parts and having to figure out how to adjust them all. Tarett sells these.
not affiliated, just have a spec cayman.
Appreciate the feedback. My current suspension is shot and my next event is in a few weeks, so decided to pull the trigger on Ohlins. It seemed like a toss up and the Ohlins were available and a few hundred bucks less. See you in Sebring @85Gold !
Peter
PTSFX (01-07-2022)
PTSFX (01-07-2022)
Basic Sponsor
I'd be curious to see some more feedback.
I have a customer car with non canister double adjustable JRZ's and it seems we have to rebuild one every year. We are looking to switch from MSC2's to Hoosiers and in the process I want to re-spring the car, so we thought we might as well upgrade our shocks but we're not sure to go to Ohlins or possibly some type variant of the MCS SPB shocks...
Another local friend and customer has what I believe are the prototype Ohlins and I thought they looked great, however I do not have much driving experience with them.
