Fikse Wheel Weight
Anyone have an idea what the Fikse Profil Series wheels weigh?? Also, if you have any idea what other brands weigh, I am all ears.
I am looking to purchase a nice, strong set of racing wheels that are exceptionally light. Any suggestions would be greatly appreciated.
Thanks!!
Thanks!!
Rich,
Try this fairly complete site. Unfortunately, they don't list the new Profil series.
I voted for the Fikse FM-10's with my wallet. Fikse has FANTASTIC customer service and is unlikely to give you a hard time if a wheel should crack, despite heavy track use.
Just call Fikse and ask them. I have a set of Profil 10s... they have quality written all over them. They're not as light as you think, but they won't fail under load.
I did a rough comparison of my '02 Carrera 18s with Rossos vs. the Fikses with S-03s. The Fikses were about 1 lb heavier in front and about 2 lbs heavier in the rear per wheel. This is just a rough comparison, especially since the Rossos had some wear on them. The Profil 10s have a lot of spokes compared to the Carreras.
The '02 Carrera wheels are some of the lightest Porsche rims around... albeit with cast construction.
One note... the "race satin anodized" finish is a touch shiny. Not over the top, but it's definitely NOT a matte finish.
that weight test might have been a bit off because it is pretty well known that Bridgestone S03s are a VERY heavy tire in comparison to most other tires.
...for example, an S03 in 225 45 17 is 25 pounds whereas the same size tire in a Kuhmo 712 is only 20 pounds...
people seem to forget that tire weight plays a huge roll in overall weight!!!
Regarding the race satin finish, NOTHING sticks to it! It really eases the clean up chore.
Cheers!
I'll second the race satin (anodized) finish. Just cleaned up my new wheels for the 2nd time and only needed a sponge and a little soap.
They do have a slightly cloudy appearance when up close, so concours participants may not like them as much as the polished finish.
The race satin is the way to go, but four days of driving at Sebring plus twelve hours of some occasional rain on the way back up ensured that my Hawk Blue compound corroded and stained the surface of the anodization as well as the raw aluminum lip. It took a 100 Q-tips, some Wenol red and a bit of time one weekend to get them back to new.
I can tell you this much. My car was 40 Lbs heavier with factory solid 18" twists & PSCs than it was with 18" Fikses & new Hoosiers. I came in 2 Lbs underweight when they called me to the scales @ TWS
If I remember right, my FM10s were 21 lbs. for the 18x10s & 19 lbs for the 18x8s.
![grr](https://rennlist.com/forums/graemlins/cussing.gif)
Originally posted by Mike in Chi
Mark
What is Wenol Red?
Mark
What is Wenol Red?
Mike and ceboyd,
Good question as I had no idea until I spoke to Matt. Wenol Red (and Blue) is a German polish that you can buy online (or maybe at your local auto parts store. None of the local places had it).
Here's some info on the stuff:
Wenol (red) Original Formula All-Purpose Metal Cleaner - Easy to use, Original Formula All-Purpose Wenol Metal Cleaner makes restoring old metals easy. This quick restorer is packed with gentle cleaners that SAFELY reach deep into metals - where stains hide - and get them out! Wenol quickly removes surface rust, oxidation, animal stains, and soap and hard water spots in just minutes. And, there's no need for hard rubbing. Simply apply a SMALL amount of Wenol Metal Polish to the surface, or to the polishing cloth, and rub gently. Then, use a soft, dry cloth and buff the cleaned area to a brilliant new shine. May also be applied with power buffers. On tough stains, rub slightly longer - NOT HARDER. You'll be delighted with the fast, professional results Wenol delivers. Not suitable for coated surfaces. WENOL cleans, polishes, and protects in one easy step to quickly restore your metals to new again.
Wenol (blue) Polish - Auto Wenol's gentle formula takes the worry out of caring for wheels, trim, and equipment - and delivers a brilliance you don't expect from a metal polish. Use Auto Wenol sparingly (a single 100 ml tube can polish as many as 50 wheels). Apply with a SOFT polishing cloth (a microfiber towel is recommended). Rub Auto Wenol into the metal GENTLY, then buff the clean surface to achieve a show quality shine. Auto Wenol provides a protective coating to ensure a lasting brilliance.
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
