I got Clake'd
#227
That is an impressively bent spring plate. Given the amount of force it took to do that, did you do a lot of measuring to make sure the tub is still straight (enough)? Or are you getting it checked on a Celette?
I've been there before (due to my own mistake, not someone else's) and it's no fun. Glad you're going through the process to get it back on track!
Yes - I actually run as a Turbolook with a little bit of a weight penalty over narrowbody 3.2s. I bought it that way and I like the looks - but I think the drag penalty outweighs any tiny benefits. It's nice not worrying about brake fade; however, I even run the same 245/275 tire combo as the narrow bodies, so there's no real grip advantage. BUT, if PCA starts awarding points for looks, 'dat *** is gonna clean up ...
