Zip tying brake sensors
Hi all,
I'm about to swap brake pads and rotors on my car. I'm going to track the car a handful of days this year so I want to zip tie the new brake sensors out of the way. I read that some rennlisters spliced and soldered the brake sensor wires together, but if like to try zip tying first.
i read here that someone tied the sensors to the strut, but am I being paranoid that there's too much movement on the strut that could cause problems with the tied up sensor? Wondering if anyone else has experience on where to secure there things. Pictures would be awesome if available. Thanks rennlist pros.
Hi all,
Murphey997 (06-14-2020)
Also, depending on old the sensors are, they may be brittle. Mine just broke apart when I tried pulling them out of the slot on the pads. The sensor is embedded in plastic and heat causes them to be brittle. I saw a post about just twisting the wires and using heat shrink over it. I did that because I don't a have a solder gun. Still working 3 years later. Not to be cliche, but if your going to the track, you need to start paying attention to the pads by visually and physically checking them.
BlackOptic (06-04-2020)
Thanks for the post, OP. I’m going to be installing a BBK and will be following this thread.
I'll take a look at what it looks like when I take the wheels off. If I can tie to the strut, then that's what I'll likely do. If not, I may just get the heat shrink. If you heat shrink or solder the wires, I'm assuming the slack is short enough such that zip tying is unnecessary?
You can unplug the sensor where it connects on the strut and then cut them down to a short length. Strip some insulation and twist the exposed wire ends to complete the circuit. Put on the shrink wrap. Plug them back in. I think I left about 2" or so and they just stick out in the open area around the strut. I'm not the greatest home mechanic. This is one of those easy things to do.
gman3280 (06-08-2020)
