String alignment question
#31
Note the precision application of painters tape to minimize scratching...
I tried just using the arms without the washers, but they weren’t quite long enough.
The following 2 users liked this post by m3bs:
Hindsight2010 (05-28-2020),
steved0x (05-28-2020)
#32
I've done something similar and then used bungee cords to hold the assembly onto the wheel at a constant pressure while I performed my adjustments or turned the steering wheel to check caster.
#33
Thanks m3bs! That is a different device from the SmartCamber, but I think I can fabricate something that will work on my SmartCamber ones similarly.
#34
Basic Sponsor
Colton Miller | Founder
CSM Performance LLC
P: +1-833-362-6988
E: Colton@CSMPerformance.com
W: https://csmperformance.com/
"Simplifying Setup."
CSM Performance LLC
P: +1-833-362-6988
CSM Performance (05-29-2020)
#36
Measure from the wheel diameter, not tires.
This helped me.
So on an 18" wheel, where I want 17 minutes toe in, I'd go to bottom chart, and find 15', which yield 2mm, and then go to top chart and find 2' which yield .3mm. So total toe in would be 2.3mm. That would be the delta between the front of the wheel and back of the wheel. That will yield 17' toe in.
Hope that helps.
This helped me.
Hope that helps.
Hindsight2010 (05-29-2020)
#37
Thank you. Wouldn't it be the sum of the delta between front and back of the wheel on both sides? IE if the left wheel had a delta of 2mm from your string, and the right wheel had a delta of 2mm from your string, the total toe would be 4mm?
#38
For example above, the 'Performance Setup' for the 991.2 GT3 Cup car calls for Rear Axle Left 17' and Rear Axle Right 17'. The chart above is a straight conversion from degrees / minutes to milli-meters.
