First Timer DE in a 928
Hey Guys, got my first DE coming up this spring.
Here's the issue: I can't fit in the car with my helmet on!
I guess I saw this one coming, it's a sunroof model, with 8 way seats, so I can barely scratch my head without the helmet on, even with the seat as low as it can go,
With the helmet... it's just not happening.
I was going to look at racing seats next. It's either that or pull the headliner panel. Or both...
Is there a fairly universal fit racing seat that will drop in and lower me about two inches? Recardo?
Looking for some ideas or suggestions.
Many thanks.
Many thanks.
One reasonable first step to consider would be checking to see if your OEM seat can be removed from the sliders and be directly floor mounted.
That will drop it a couple of inches.
If you check w OG Racing Mark may have a compatible floor mount for your car. BreyKrause makes some universal mounts.
Many thanks.
Many thanks.
In the Miata world many people perform a "foamectomy" to remove the foam from the seat bottom to gain extra head room with stock seats. I don't know if that's feasible but it might help if you don't have other options.
I want to thank everyone for the good ideas.
Exactly what I needed.
I will start looking at these options.
I’m a gangly 6’4, so it’s a challenge. Further back would be good too.
I’ve got a extra set of OEM seats, it didn’t occur to me but maybe there is a way to delete all the power and lower it as well? Conversion to manual, manual seats were always lower somehow right?
I’d have no hardware to adjust it so it would have to be in a desired fixed position.
I know that’s rambling.
As an aside, I couldn’t believe how old my car is compared to the rest of the DE group!
I’m 50 percent of the transaxle P cars going.
Everything else on the roster is new
928 DE
Stiffer springs and sway bars, limited slip, rising rate fuel regulator, wider wheels and tires, it is a slippery slope
Greg
I DE'd for years in my 928 at 6'1" it's not easy. But lean back and move it forward to reach the pedals. There are two sets of holes in the floor so you should be able to start at the furthest back setting.
Our club NRPCA is very strict for seat changes. Make sure you check with the group your running with and if you plan to continue with this car. You can't run race seats without harnesses as the three point harness is not designed for the race seat positions.
Some clubs don't allow harness bars only half cages (bolt in but might have to be weld in)
PCA is mandating Head and Neck restraints when using harnesses. You also need to have equal on both sides of the vehicle.
This is where people begin to look at integrity of the street car (cost if upgrades required) and costs of a race car...
I'm a bit surprised that the answer is basically to have a sub optimal driving position (reclining the seat)...
It doesn't seem to me that it would be the safest nor the most comfortable solution.
I'd look at race seats and/or mount the seat on the floor.
On most race seats cushions can be removed as well.
