The physics of racing - A long, technical video presentation
This is a 1.5-hr classroom-style lecture, and I found it very interesting. Wanted to get feedback about how good it is - are there any blatant inaccuracies, misleading info, or is it pretty good?
Basic Site Sponsor
Basic Site Sponsor
Received 3,340 Likes
The author, in a 488C at Misano.
Video and on screen data using RaceNavigator.
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
I'm in....
I watched it. He does a good job.
One thing I was surprised by was that he didn't mention the downside to maxing out castor which is that it increases the wheel base.
Really exceptionally interesting and useful
This is really exceptionally interesting and informative. Thank you for sharing
https://youtu.be/bYp2vvUgEqE
I finally had time to watch this. That was done very well and an excellent speaker! I loved all the math incorporated into the lecture for each point.
Even if you're not into the math, I think you can understand why we do the things we do to our cars to make them go around the track faster. It should also become apparent how complex car handling is and how changes may not always do the thing you expect. Sometimes you just have to experiment.
Thanks for sharing
Thanks for sharing
Blue Chip :I would suggest that you read https://www.caranddriver.com/feature...11-gt3-feature
This story is based on putting both cars on a 7 post rig...
Ray
Ray
Ray
Ray
If you could take the same GT3, flip the motor over the rear axle, move it up about a foot, and hang the tranny over the rear axle (like the new 911 RSR), then repeat these tests it would better.
I had a conversation with the guys who ran the tests (the 7 post rig) and it was interesting. I asked exactly the same questions WRT Polar Moment and the hypothetical equal HP, tires, etc . There generalized comment was the the 911 (GT3) chassis was better at the limits than the Caymen. They also indicated tat they did not post all the data (in the story) than was generated.
aryork: WRT rearranging the motor / transmission absolutely true, no argument there, but the generalized comment was that the Caymen would never be as good was hat struck me.
Ray
Ray
Ray
Ray
G-Circle: GT3 wins based on total tire size versus total weight, nothing to do with weight distribution. Also bonus points for ("911s are known to be hard to handle at the limit, but this long, steady state corner is totally where we will disprove that!")
Slalom: Both of those were so poorly driven that there is absolutely nothing to be gained from that test other than driver dispersion.
"6 turns": you see and hear them get to full throttle between the turns so obviously the implication that they are tight enough to eliminate that is wrong. More importantly though, the tire compound and overall higher level of grip from more tire.
Spin Threshold: might be the actual dumbest test of the bunch. At full throttle the 911 has far less weight on the nose so is going to experience understeer by rapidly adding 90 degrees of steering... which will essentially allow it to "pass" this test since the only criteria is when does it swap ends.
I think it is well proven that the GT3 has a higher limit than the Cayman R - as it reasonably should given its position in the hierarchy and the specs of the two cars. But this test "scientifically" attributes that to the weight distribution which is just silly.
-Mark
