Lambo Hard Crash at Laguna Seca
#31
that was actually what saved her. the fact that the car has the low nose, ( blunt nosed car, might have just stopped) it immediately allowed the rear of the car to come up and get airborne provided more time for her lateral decelleration . all that energy lifted the car up 10feet or so and then it dropped. had it just stuffed into the wall, she might have not been so luckly. over the wall is not as bad as it seems.. i would rather go over the wall than just stop at the tires flat and level.. (depending on what is on the other side. My friend Gavin had a major crash at Road America where he jumped the wall after turn 1 sand trap during Speed GT race....... it was a wild ride for him. right now, I dont know what Laguna could do to make that corner any more safe, unless they added more tires.
Think about all that energy released to lift a 3000lbs car 10ft in the air in that amount of time..... i dont know the speed she was traveling, but people dont survive 80mph to 0mph impacts very often.
I don't know much about these Lambo's but is it safe to assume they are F1 style paddle shifters and even if there was something wrong with the brakes that she would only be able to downshift once or twice because the gearbox wouldn't allow anymore as a safe guard against over revs?
#32
I'd like a materials spec on the net that catches a several thousand pound car traveling at 100+ mph and decelerates it a slow enough speed to be useful while not acting as a slingshot for the car in the opposite direction once deceleration is complete and also doesn't need multiple support posts that create their own hazards. Sounds like amazing stuff.
#33
So glad she is ok, that was an incredibly hard crash, much worse than what took Earnhart (open face helmet, no HANS killed him).
Seems they improved the safety on these cars, I was going to rent a ride the first year they were out but after sitting in one I thought it very unsafe, and
saw some catching fire...
Huge movable heavy concrete blocks behind tires saved my chassis at Sebring (I moved it quite a bit), maybe that could be considered in that area.
Hope she will race again soon!
#34
decelerating the car from 100mph by itself would be possible as well. and again, you need to think of the energy required and then calculate the room for what it would require. the good news is that the corkscrew has a lot of room on the backside of the barriers............a very simple solution would be the tires , with the wall replaced with a heavy net. it would be designed to allow the tires to move the net hydraulically. then, after the impact it can be pulled back into position. either manually by use of a toe truck , or if fancy, automated.
they also have some that are used for runaway semis on the mountain freeways.. I'm not saying to get a net to save the car, but a simple system to just extend the decel distance from 4-5 feet to 2 to 4 times that. very doable, without anything that fancy.
https://www.youtube.com/watch?v=DolytF0Uf2A
Go to 40 seconds
#35
I don't understand what you are trying to show me. So a car flies over the ocean and onto an aircraft carrier? Based on my calculations, the car would have to travel very very fast. How many aircraft carriers are we going to need?
#36
the point is, they need to make a catch net on the other side of the wall , If the technology existed to stop a plane at over100mph with no damage, im sure a variation of the concept could be created to slow the cars down using portions of that technology. It's all about just getting a little more room for decel aftter impact. Since most of the cars flip, taking some energy out by the wall moving or by use of a catch net if they go over the wall. since cart is not coming back, cars going over the wall , is not likely............but there have been many straight on impacts.......... some time of barrier that moves and maybe includes a net might mitigate the impact forces.
https://www.dailymotion.com/video/x6aqge2
#37
I have seen a number of incidents involving these Supertropheos when I've been on track with them. I will say that they must be built incredibly well as I've never seen anyone injured including one that penetrated the armco at WGI.
#38
Received 1,729 Likes
But I agree going over the wall might be a better option given how little protection exists for a direct head-on.
#39
That's one option. And raise the height since it's relatively easy to get airborne at that spot. Relatively short run off/gravel trap and a cement wall with the potential to be impacted head-on at high speed - two or three rows of tires doesn't cut it IMO. That's exactly how Sean Edwards died.
#42
That's a new one... smdh.
"Nets" (catch fencing) killed Gilles Villeneuve... That's one of the reasons why they don't do that anymore.
Witness also the "catch" fencing contributing to the serious injury or death of several IRL drivers...
The intial hit is the one that hurts or kills you. After that, you're just along for the ride...
They have some success
https://youtu.be/hZegY89juh0
#43
Basic Site Sponsor
Basic Site Sponsor
Received 2,837 Likes
I don't know. I just remember Scott Kalitta...
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
#44
Going over the Wall didn’t work very well for Rodriguez. Of course the track safety was improved greatly because of this crash. There was was much less run-off area and only one row of tires....
#45
