Race pads, when do you change them out
At what minimum thickness do you change out your front pads?
Thanks,
Thanks,
Basic Site Sponsor
Basic Site Sponsor
Received 2,837 Likes
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
Most event forms require a minimum of 50% pad thickness to start an event.
Basic Site Sponsor
Basic Site Sponsor
So, a little more than a quarter inch is 50% wear, so about .300" thickness, or about 7-7.5mm, which is the thickness of the typical backing plate.
IAW with Clark's reference chart your numbers come in approximately 3/16" thicker overall.
I think it depends on the brake system. Every system has a weakest link. Full pad is better like new tires but how low can you go? Around 2010 in scca T1 a c5 vette racer was airlifted out at Runoffs from an exploding rotor with brake failure. We complained earlier and often for an aftermarket brake allowance for safety. We got it after someone got hurt. Stoptech knew our problem and designed and tested their SCCA T1 brake kit on my c5 vette racecar. It is so over engineered that I can and have raced my pads down to a millimeter of the pad backing with no percievable loss of braking ability while rotors last at least 1 1/2 years. And I don't bed in pads or cryo rotors nor season them.
so you have to track your system and log some data or you will probably spend more on consumables
Rennlist Hoonigan
which cost no drachmas
Brake performance at the top level is a very deep rabbit hole. Things like caliper stiffness, age fatigue (hardness changing), seal performance, seal material, seal aging, assembly oil, all make big differences. Then in the pads themselves, some compounds oxidize over time after they are heated, so their performance changes with just time (not use). Some are very stable in regards to oxidation, but can have other problems. Depending on the brake pad material, pads have different thermal conductivity. This thermal conductivity changes how much heat gets to the caliper and then you start the whole seal, stiffness, flex problems. You also have different alloys in calipers where some deal with high temps better than others.
When you don't have control over most of those items, like in a street car, look at the overall wear rate for the track your going to decide from there.
Your original comment stated :
After 50-70% my pedal travel told me it was time to change them. I like the nice high brake pedal new pads and fresh fluid gives..
Surely there are other variables, but you did not specify as such. I'm merely commenting on your post which might seem highly intelligent to you, but not to other readers having to guess where you are coming from.
