Tracking on slicks in the winter - sidewall cracks
Originally Posted by consolidated
Thanks guys! I'd be very happy with 15 HCs.
R7 is actually an excellent tire...but if you go DH and learn to drive them, you'll never go back
Depending on your car, mix of tracks, and driving style, up to 20 decent cycles are realistic with properly broken in DH's. They are a wonderful tire, and quite forgiving (for a full slick). Astounding grip. Rewards a smooth, precise driving style.
Just in case anyone had a track day coming up and runs NT01's like I do...
https://www.nittotire.com/media/4102...r-climates.pdf
Originally Posted by GeoJoe
Aside from visually inspecting the "wear dots" across the tire width and slowly watching them get less deep, what's the best way to gauge the DH's remaining life? Butt dyno method?
Whenever it seems you just can't warm them up enough to start biting...they're done
I have a durometer, and it has been all over the place. Bottom line is how the car feels. Besides, the handling of the car is going to be the way you calibrate the durometer anyway, meaning what threshold you will use to say the tire is toast. I've corded DHs. I think they can (sometimes) have useable life right up until the end. It depends how they were used , both before and after you get them, and that is the downside of take-offs.
what experience has the group seen with R7's at cold temps. I know Hoosier says keep them above 40 degrees. that said, I've seen people run them regularly in upper 20's and 30's. Are the hearty enough to run those temps or are these people just lucky.
