How safe is Radical SR3 or new SR1 for DE
#93
Why isn't there a full windscreen on the SR3, fully protecting the head from debris projectiles? The thought of getting hit in the helmet by a large rock at 150mph doesn't sound appealing -- not to mention a metal/mechanical part off of another car.
#94
Her is a shot of my helmet with the clear bra and tear offs
#95
[QUOTE=CharleyH;14749878]
I understand your concern, but I can tell you that in the four years I have been tracking my Radical it has never been an issue. Your helmet certainly gets hit by debris but it is mostly excess tire rubber and small stones. I have never been hit by anything that concerned me... although in the spring bug splats can be sort of comical. You will notice that the front of your helmet and face shield get pitted over time. For a few years I just replaced replaced my face shield when it got pitted...then I started using tear offs and put clear bra on the front of my helmet and that has done a great job of protecting the helmet.
+1 Has not been an issue in my experience racing and lapping the car
#96
My main concern would not be pits and scratches to the visor and helmet from small debris, but the (admittedly much rarer) bigger hits from larger pieces of rock/gravel or mechanical/metal debris (nuts, bolts, parts) lifted in the air by the car in front. I keep thinking of Senna as I write...
Anecdotes are not very helpful with rare, high-downside events. Is there a statistical study that relates/quantifies the increased risks of sitting lower in an open cockpit (without a windshield) vs. racing in a closed cockpit?
And my question remains, is there a downside to having a windshield in the SR3 or similar open cockpit cars?
#97
perhaps that can be a question you address with Radical
our speeds are significantly slower than f1 or Indy, thus reducing the velocity of an impact
fwiw, i spent lots of time on youtube looking at radical accidents, and talking to long time racers of the cars
I was comfortable
#98
To to answer your specific question I am sure a windshield could be added if someone really wanted one but It would take some work and would likely affect the cars aerodynamics.
Charley
#99
I guess all motorcycles racers, SCCA Spec racers, HSR racers, Formula mazda, ford and on accept the risk. I thought about it too but decided racing is risky but so is driving thru Atlanta. I guess if you want the safest racer look for an ex-NASCAR ride which would be cool and fast.
#100
Appreciate the answers. I just read the Snell SA2015 visor testing procedure: 1gram, 5.5mm lead pellet shot at 500km/h into the visor. The weigth seems too small and the speed too high, but overall not too bad. The new, more stringent EA2016 standard sounds interesting though the visor procedure is the same:
http://www.smf.org/stds
When going over crests in light high-downforce cars, do you have to be careful that not too much air goes under the car and lifts it? Do you purposefully slow down for crests to avoid this? How do you know how fast is too fast -- or how much air below is too much?
#102
Basic Site Sponsor
Basic Site Sponsor
Received 3,340 Likes
No. Only at the most abrupt crests do you need to even think about any possible unweighting of the car, and the very cars you’re talking about are light, low, wide and the body itself functions as a downforce generator.
The faster you to, the more stick you have. Not like GT cars with stuck-on wings and splitters designed to trim the aero balance in fast cars, because as a percentage of weight, the GT car’s downforce is a fraction of the percentage of the purpose built car’s downforce.
I’ve never seen a properly set up sports racer require ANY sort of speed moderation! Only if the ride height abs rake was totally out in left field would you ever see any lift at Tremblant, VIR Climbing Esses, LRP or any one of dozens of crests in North America, in my experience.
#103
there is a crest at area 27, which the radical takes flat out (Area 27 Radical onboard on youtube link in signature)
have to open hands once crested and weight returns to front tires
i got the car last summer, and i'm still getting comfortable keeping my foot down
#104
At a track the things I’d really worry about are getting squashed by a big sedan and running out of talent.
#105
Have raced there SR3 at many tracks across North America and aero induced lift has never been an issue, especially not at Barber in turn 3 as an example - quite the opposite as the car is on full throttle and loaded nicely coming over that crest. Esses at VIR are flat no problem as an other example even if you do use a bit of curb on the way through.
Turn 1 Sebring (I know its a level turn, but there is a might bump in there), or turn 10 VIR (South Bend, blind downhill left hander) are a little different as they require commitment from the driver to get the maximum performance from the car and some throttle modulation is needed for many.
