How close are my NT-01s to done?
Old 10-24-2017, 11:24 AM
Conekiller
Conekiller's Avatar
Thanks I'm running 2-2.2 front and rear I'll have to see if I can dial some more in. As I need to flip them halfway through to get the most life out of them
Old 10-24-2017, 04:08 PM
rlm328
rlm328's Avatar
Originally Posted by zedcat
So you can still see the little dimples on the inside and outside? When these get faint for me the end is near. I usually run them until they cord which happens about 25 to 30 sessions. this one is 26 sessions. Car is a 987.2 Cayman R.
This tire is starting to cord.
Old 10-24-2017, 04:16 PM
mark kibort
mark kibort's Avatar
Originally Posted by Spinout
Drive them until they cord. NT01 s get grippier as they wear. I had 30 heat cycles/sessions on these before I had to pull them.
thats a very strange wear pattern. inside and outside. maybe raise the tire pressure a tad?
that tire is done
Old 10-24-2017, 04:33 PM
TXE36
TXE36's Avatar
For NT-01s, the cords are the wear bars .
When mine are not long for this world, I bring a second mounted set with me. When those cord, the new ones go on, the ones from the old set not corded go in the "reserve" pile and they get used up when this new set cords, by which time there is a new set mounted and ready to go. I seldom toss out an NT-01 that is not corded.
Having lots of spare wheels helps.
-Mike
Old 10-24-2017, 06:10 PM
Spinout
Spinout's Avatar
No can do. I run 36-38psi hot pressures. I think it's an impressive wear pattern after 30 sessions or so.
Quick Reply: How close are my NT-01s to done?
