How close are my NT-01s to done?
Old 10-21-2017, 05:05 PM
dbbarron
dbbarron's Avatar
Default How close are my NT-01s to done?
10 event days (slower white pace). Many dual driver days (counting each as 2 days).
Center tread groove at 4/32. Right at 'wear bars'
Outer edges lateral grooves just scrubbed off. Inside a little lateral groove remains.
Likely around 30 heat cycles.
Thinking I will heat cycle out and/or cord outer edges before I wear through main surface.
Old 10-21-2017, 05:50 PM
Jferrante
Jferrante's Avatar
30 heat cycles I would toss them regardless of wear. I would usually go to 20-25 on mine before tossing them.
Old 10-21-2017, 05:57 PM
dbbarron
dbbarron's Avatar
How do you count heat cycles for DE days?
We have 5 run groups, 21min each, so 21min run and 110min between plus extra time at lunch. I count that as 4 heat cycles for the day.
When we dual drive, if back to back, same things, if spread out, might only be about 2 cycles for the day since there might only be 21-42min between runs and the tires don't cool down that much.
Sound about right?
Old 10-21-2017, 06:32 PM
zedcat
zedcat's Avatar
So you can still see the little dimples on the inside and outside? When these get faint for me the end is near. I usually run them until they cord which happens about 25 to 30 sessions. this one is 26 sessions. Car is a 987.2 Cayman R.
Old 10-21-2017, 06:35 PM
dbbarron
dbbarron's Avatar
I can definitely see the dimples - depth of 0.150".
I'm also at the same 30 sessions or so, but nowhere near the same wear as you.
Old 10-21-2017, 07:55 PM
dbbarron
dbbarron's Avatar
I have a new set of NT-01s in the garage and the used ones on the car.
Will checking them against each other with a durometer indicate whether they have heat cycled out?
(i.e., should I buy a durometer)
Old 10-21-2017, 08:56 PM
Thundermoose
Thundermoose's Avatar
I run NT-01's to the cords
Old 10-21-2017, 09:11 PM
ExMB
ExMB's Avatar
Received 1,366 Likes on 831 Posts
Old 10-21-2017, 10:20 PM
mglobe
The Penguin King
mglobe's Avatar
This
Old 10-21-2017, 10:52 PM
Frank 993 C4S
Frank 993 C4S's Avatar
These tires don't really cycle out. Run them until they cord, unless you have to drive them from/to the track in which case you better have some thread left for possible rain on your way home.
Don't ruin your weekend by cording your tires in the first session, having to go home. Put your new tires on.
Old 10-22-2017, 01:34 PM
Spinout
Spinout's Avatar
Drive them until they cord. NT01 s get grippier as they wear. I had 30 heat cycles/sessions on these before I had to pull them.
Old 10-22-2017, 10:25 PM
Matt Lane
Matt Lane's Avatar
Concours
Old 10-23-2017, 09:49 AM
Conekiller
Conekiller's Avatar
Wow those are wearing really well. How much camber are you running? Mine always seem to wear out the shoulders first
Old 10-23-2017, 10:23 AM
steved0x
steved0x's Avatar
I was thinking the same thing!
Old 10-23-2017, 01:29 PM
Spinout
Spinout's Avatar
From my most recent setup: -2.5 at the both rears.
Camber (Degrees)
-2.5 -2.9
-2.5 -2.5
Camber is maxed out at each corner currently. I've recently added adjustable LCAs on the rear but haven't dialed them in yet as I'll be adding the fronts next month. I will increase camber up front w/a new alignment then.
Quick Reply: How close are my NT-01s to done?
