"Raising Ride Height" - Carrera GT
I just received a 2-page fax from my Porsche dealer, dated 5-3-05:
Vehicle Type: Carrera GT (980)
Model Year: As of 2004
Concern: Raising vehicle ride height
Information: To reduce the risk of the vehicle underside bottoming out and/or getting high centered on uneven roads, speed bumps, steep angle driveways or parking garage entrances, the chassis on the Carrera GT can be raised.
Front axle: 10 mm / rear axle 9 mm
This is done by installing longer push rods on front and rear and increasing the spring preload (on rear only). The spring preload is modified by turning the concave washer clockwise by three turns. Raising the chassis does not affect driving behavior in normal driving conditions.
Parts Information:
Part Number 000.044.500.40 - Push rod set
Set includes:
980.343.257.04 (1) Front axle push rod, left
980.343.258.04 (1) Front axle push rod, right
980.333.257.04 (1) Rear axle push rod, left
980.333.258.04 (1) Rear axle push rod, right
900.817.003.02 (4) Lock nut (M10), upper push rod
999.084.016.02 (2) Lock nut (M10), lower front push rod
900.380.008.09 (2) Hexagon nut (M10), lower rear push rod
(now comes a tool list and some work procedures which I am too lazy to transcribe)
Vehicle height, DIN empty (mm)
Raised Ride Height / Standard Ride Height
Without underbody panels:
Front 141 mm / 131 mm
Rear 168 mm / 159 mm
With underbody panels:
Front 102 mm / 92 mm
Rear 119 mm /110 mm
Working Time:
Labor Operation - 44 95 31 00
Description - Vehicle modified front and rear
This includes: Removing and installing 4 wheels, Removing and installing 4 push rods, Adjusting rear vehicle height. Without: Performing suspension alignment and adjusting vehicle.
Time Units - 250 TU
Parts Information:
Set includes:
Rear 119 mm /110 mm
Working Time:
Time Units - 250 TU
Mike ,I presume that this modification is not driver ajustable. I was hoping for an active suspension solution from Porsche as in the Enzo. Cockpit control just to get you over the tall obstructions. Seems to me that maybe they could adapt the ajustable air suspension off the Cay TT to effect a driver ajustable ride hight on the CGT. Thanks for heads up .
this is terrific news, however, not just any dealer can handle this operation. i don't even think either of our dealers can align a CGT. if there was a dealer relatively close that was capable of performing this, i'd do it in a second.
So I don't think any type of alignment is required.
I am going to call my dealer and see if they are able to do this while I am gone on business next week.
my read was that the "without: performing suspension alignment and adjusting vehicle" referred strictly to the labor listed. iow, the labor listed doesn't include that stuff which while still necessary is not included in the estimate. you can't raise a car 10 mm without realigning it can you? neither of our porsche "premier" dealers here can align a CGT.
I have a call into my dealer, the Carrera GT guy is supposed to be back any time and give me a call back so I will let you know what they hear.
Originally Posted by themarsman
... So I don't think any type of alignment is required.
In my original copy, the layout makes clear that the "without" part is intended to mean that the time to align and adjust the car is above and beyond the 250 time units required to install the hard parts.
I wouldn't dare get this sort of thing done to my car without an alignment!
It is scary to think that your premiere dealers can't even do an alignment of the car if necessary..
btw mike, how much time is 250 units? tia
Originally Posted by hyroller
Ben,250 units is 2.5 hours according to my P dealer.
btw, very nice color combo selection on your CGT
Thanks Ben. I guess that we're kindred spirits when it comes to color choice.
If one cant use the car at standard ride height, then they are buying the wrong car, just my opinion, my main concern about driving a CGT would be damaging the Carbon, not a cheap fix.
