Rear Hatch wont open
I wired my Battery charger into the engine bay, and today when I went to disconnect it, the hatch wouldnt open. The battery is fine, I can hear the mechanism working, but it wont pop open. Even had the wife pull the latch while I pushed and pulled on the hatch to no avail. Any ideas? Thank you!
The following 2 users liked this post by bbs993tt:
911Vintage (09-14-2020),
MirageJHU (09-12-2020)
Have someone shine a light through the rear tail light- towards the ground. That made it super easy for me to find the wire Brian references above.
You have to be pulling the liner back a bit and I used a coat hanger, but a long pick tool could help too. Here's the thread Jimmy started https://rennlist.com/forums/porsche-...operation.html
It's pliable - you can just bend it back in a small gap and get a tool in there...
Basicly,, the actuator sits below the latch. Once I got the plastic cover off that covers the latch, you could see the actuator just dangling there. The actuator just slides in to 2 screw points and you tighten when you have slight pressure on the latch linkage. You can see how over time its possible for the latch to work itself loose.
Basic Sponsor
Was Happy to help, and relieved it was something as easy/free as re installing the actuator. I have experienced this failure a handful of times personally. I will create a write up walking everyone through the steps I helped Allan with as its fairly easy and avoids a trip to the dealer.
As always, I am here to help!
The Standard In Porsche GT Service
(203)257-0987
Info@RepasiMotorwerks.com
www.RepasiMotorwerks.com
(203)257-0987
The following 3 users liked this post by jimmyrepasi:
