Shock Potentiometer Advice
Would anyone have pics of how they have mounted shock pots to a 997 cup?
Better yet, the travel and overall length they used front and rear? I am sure a safe stroke will not be more than 100mm, however the overall length might be the determining factor depending on where/how they are mounted.
Here's a pic a ran across:
http://photos.motoiq.com/MotoIQ/Feat...JEF6296-XL.jpg
From this article:
http://www.motoiq.com/magazine_artic...e-911-gt3.aspx
Hope it helps.
From this article:
Hope it helps.
Der ABT (05-17-2021)
TEdean
I put some on a 996 cup a couple years ago and am doing a set on an 05 Cup next week. I believe I used 150 mm Penny and Giles. I don't think 100 mm is quite enough to cover full droop to full compression (on the bump stops). I don't have a full set here currently. Are you running AIM or Motec? Matt is actually using a different type of pot on his car. He'll need to fill us in on that. I'll take photos and provide details next week
If it is convient to take pics, great. Don't want to cause problems. i am using MoTec. It is my winter project (puzzle).
Tommy
On a 997 cup just how much does the spring compress before it binds?
From H&R catalog/cup pdf
2006-2008:
F:85= 49+36
R:88= 58+30
2009:
F:85 49+36
R:93.5= 57.5(?estimated)+36
2006-2008:
F:85= 49+36
R:88= 58+30
2009:
F:85 49+36
Rennlist Hoonigan
which cost no drachmas
I was - until I saw the price - 3x a normal sensor!!!!!! I'm going to go with regular linear potentiometers. I have to get measuring and double check the lengths. I think I'm going to be 150mm in the front and 225mm in the rear. I found some that go to 350mm too. BTY - the is all for a 914, not a cup car.
Basic Site Sponsor
Basic Site Sponsor
Received 3,082 Likes
Matt, PM me some pics of where you'd mount 914 pots, please.
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
Hmm - sounds like you guys are set up with waay more travel than my GT3R. I have some shock pots on the shelf, but haven't mounted yet. I got my shocks from a 3R racing WC car and they have less than 75mm of total travel before they hit the bump rubbers.
The rears seem straightforward enough, it's the fronts that are tricky because of the turning strut. Would love to see some pics of an install for ideas...
Rennlist Hoonigan
Maybe? Most won't react fast enough because the spring isn't strong enough to rewind. The string will get a little slack as the suspension rebounds and then rewind real quick. It ends up showing higher shock velocities than what really occurred.
