Shock Potentiometer Advice
Old Feb 26, 2016 | 08:04 PM
  #31
Rickard 993 Turbo's Avatar
Rickard 993 Turbo
Sounds perfect
Any one have the motion ratio for a 997 cup or maybe it's different on 2013 gt3 R geometry ? It should be little different I think mostly in the rear
I have uppgraded to a adl3 with 250mb memory 50 I/O and pro logging so i have it all for maximum logging
Yes please email shock spread sheath
Old Feb 26, 2016 | 10:13 PM
  #32
amso3's Avatar
amso3
Motion ratios will be easy once you zero the shocks. Raise the car so that the tire lowers 1" relative to fender lip and see what the pot distance is. Shock movement divided by wheel movement will be motion ratio. Different front to rear.
Old Feb 27, 2016 | 06:17 AM
  #33
Rickard 993 Turbo
Then I do a math channel for wheel motion ?
Old Feb 27, 2016 | 09:06 AM
  #34
amso3's Avatar
amso3
You could do a math channel or you could calibrate the potentiometers to show wheel movement rather than shock movement. I don't know the ADL 3, but with AIM you can pick the sensor to be a mid zero type and you do a manual calibration by moving the wheel and define the distance moved. I'll look at the ADL 3 config and see if I can find how to do it
Old Feb 27, 2016 | 09:08 AM
  #35
Rickard 993 Turbo
Wouldnt it be best to have both..?
Or is the wheel motion the most important, i think the math channel will be done in the i2
Old Feb 27, 2016 | 09:38 AM
  #36
amso3's Avatar
amso3
The shock movement is needed for analysis, so it would be best to do a math in I2 Pro to show wheel movement.
Here is a link to my website where I have an article that I found about shock speed analysis. You can download it from here http://austinmotorsportsllc.com/docu...ce-information
Old Feb 27, 2016 | 11:13 AM
  #37
Rickard 993 Turbo
I have now done a math channel and it works fine so now i can se both the shock movment and the wheel movment..
When i have had my first track day i can post the loggs so we can tune the suspention here on Rennlist..
Old Feb 27, 2016 | 11:17 AM
  #38
Rickard 993 Turbo
Also
Wouldnt the wheel movment and the shock springs give me DF level also or do i need more info for that..?
Or do i need the Hz for this..?
Old Feb 27, 2016 | 12:17 PM
  #39
Rickard 993 Turbo
Also
Old Feb 27, 2016 | 06:58 PM
  #40
georgemcf's Avatar
georgemcf
Originally Posted by Matt Romanowski
Very cool. Then you will have great shock data. You'll only need the motion ratios if you want to know ride height changes or other chassis info. You'll be all set for shock tuning. Do you have the shock spreadsheet from Jorge Segers? If's awesome. I can share it if you don't have it.
I am intersted in the spreadsheet . I just installed shock pots in our 2010 R in New Zealand. I feel with all this new data I am going to have to play with, my uni degree is going to get less attention
Old Feb 27, 2016 | 08:14 PM
  #41
amso3's Avatar
amso3
Rickard
What do you mean by DF Level
Old Feb 27, 2016 | 08:30 PM
  #42
Rickard 993 Turbo
Rickard
Amounts of downforce
Old Feb 27, 2016 | 11:14 PM
  #43
rbahr's Avatar
rbahr
Hi All,
The spreadsheets and info can be found here: https://sites.google.com/site/jorgesegers2/technical
Ray
Old Feb 28, 2016 | 12:36 AM
  #44
Matt Romanowski's Avatar
Matt Romanowski
Rennlist Hoonigan
which cost no drachmas
^^That's it! Thanks Ray - I didn't know he had it up on that page.
Old Feb 28, 2016 | 08:36 AM
  #45
amso3's Avatar
amso3
Rickard
Yes, the potentiometer movement and the spring rate will allow you to determine downforce (approximate), however, the track needs to be very smooth or the shock movement will be too "noisy" to get good numbers. If you are doing that test, I'd re-zero the shocks on level ground just before the run, to get a good reference.
