Porsche Cup Cars
Jack stands for cups
Old 05-17-2012, 11:33 AM
Phokaioglaukos
Phokaioglaukos's Avatar
Default Jack stands for cups
I have seen the nifty two-stage stands for use with air jacks that allow the car to be raised to twice the height that the air jacks alone, but they are very expensive.
I have also seen people at the track with cars up on air jacks but with four non-adjutable jack stands at the four "normal" jacking points acting as a safety for the air jacks. I thinking having a set of those would be wise. Do you know of someone selling those ready made or do I need to have someone fabricate them to my specs?
Old 05-17-2012, 01:25 PM
JoeMag
JoeMag's Avatar
I took a regular jack stand and cut the legs down to make it shorter. replaced the insert with a piece of channel with square tube welded to the bottom of it to go into jack hole.
Old 05-17-2012, 02:35 PM
K964
K964's Avatar
PM nmercier853 here on Rennlist. He sold me a custom aluminum set he made a few years ago. He might have a few more lying around.
Old 05-17-2012, 02:43 PM
J richard
J richard's Avatar
^^^+1 I bought a set as well. They work fine and are very light. If you want the factory ones they tend to be big $$$.
Old 05-17-2012, 02:45 PM
Phokaioglaukos
PM sent....
Old 05-17-2012, 03:40 PM
TruSpeed
Former Vendor
TruSpeed's Avatar
JT of Tatum Racing just started to make custom ones. Maybe give him a call, (954) 240-0335. Let him know that Sloan gave you the referral
Old 11-07-2012, 01:39 AM
HiWind
HiWind's Avatar
Apologies for using an old thread but hoping one of you can help .....
Do these go inside the collar on the bottom of the car tub or around the outside? I imagine it wouldn't be good for the stand to rest on the air jacks seal or even on the Ali locking nut around the jack, but I might be wrong? Ps - the front jack doesn't have a collar, so that's easier but for the rear two ..... Thanks!
Old 11-07-2012, 01:27 PM
J richard
J richard's Avatar
Hiwind,
The ones that I have are about 10" tall 3 1/2" aluminum tubes w/a 10" round aluminum base and a handle. There are four of them that go under the standard factory jack points. They also work great on the boxster. The collars that go around the airjack itself are machined aluminum and the bottom of the jack collar sit on them. There are one per air jack. There is also a safety collar that goes around the jack shaft if you needed some security getting under the car while the jacks are down, but not for extended use.
Old 11-07-2012, 03:23 PM
HiWind
HiWind's Avatar
Thanks JRichard - i found these - any real reason to go trick over simple?
I know 2/4's w little door handles would work too ... But keen to get the grinder out
The Trick Stands
The Simple stands
Old 11-10-2012, 11:16 PM
nmercier853
nmercier853's Avatar
I make the aluminum ones that most guys have. Send me an email if you are interested. I can send you a set right away....thanks for the nice comments above
Thanks Nick
Nmercier853@Hotmail.com
Old 11-11-2012, 02:19 AM
HiWind
HiWind's Avatar
Hi Nick - how tall are they? Do they just fit under the car when air jacks are extended and then you release some air to engage the Ali stands you have?
Old 11-11-2012, 08:52 PM
nmercier853
The stands are 9" tall so they just slide under the cars body work and are positioned where the (4) jacking points are. I usually pull the air wand off the car and leave it up or release the air and let the car sit on the stands when I am doing any work to it.
Old 11-12-2012, 01:03 PM
Bill911
Bill911's Avatar
Great stands!!! I have set.
Old 11-12-2012, 02:28 PM
HiWind
HiWind's Avatar
Thanks guys
Quick Reply: Jack stands for cups
