Porsche Cup Cars
WTB Nitrogen hose and 450 psi Nitrogen regulator
Old 01-14-2014, 08:56 PM
  #46
chrcook
chrcook's Avatar
I depressurize before swinging the elbow. No worries.
Oitiker also has high pressure ones, which is what the pro team I've seen use. Then really no worries.
Old 05-22-2014, 01:46 PM
  #47
Phokaioglaukos
Phokaioglaukos's Avatar
I have had bubbles form in two different Gorilla hoses, each rated for 500 PSI but used at pressures less than that. I'm changing to the pressure washer hose.
Old 05-22-2014, 06:19 PM
  #48
Steve113
Steve113's Avatar
I had my local Hydraulics company make up a custom line with all the right fittings . Best part is I had it cut to the length I wanted and its good for something like 2,000 psi . No need to worry about bleeding it down to stop bursting. Cost under $200 with all the fittings
Old 06-09-2014, 01:12 PM
  #49
crashtest22
crashtest22's Avatar
after having a second regulator fail I have decided its time to bite the bullet and get the Paoli B.40.0002.
I am also thinking while I am at it to get a hose from them.
I do find it interesting that most of you guys have been able to get away with a 450 psi reg as I cant even get the rear to budge at 450 psi.
I need 5-550 to get the car off the ground.
that regulator if I do the math right is mid 600 bucks but we have spent that on supposedly good 600 psi rated regulators that have failed already
Old 06-09-2014, 05:49 PM
  #50
cup997laurent
cup997laurent's Avatar
my hose and reg are 16 years old, never change the hose ! i think it's hidraulic hose , a bit rigid but really long-lasting ......
Old 06-09-2014, 06:12 PM
  #51
crashtest22
the hose we currently use is blue and designed for steam cleaning/carpet cleaning.
it is stiff but works just fine.
Quick Reply: WTB Nitrogen hose and 450 psi Nitrogen regulator
