By larger graph, do you mean one that's a bit more legible? I have the original and unfortunately, it didn't scan that well.
This was done AFTER the updates. Full factory '08 spec, including ECU re-map and intake. It has the '06 original exhaust.
Went with JRZ 3-way adjustables for the dampers.
A bit tiny, but it looks like you ended @ 423HP which should be right in the ballpark. ECU remap is factory unit I suppose. You've got some damper setup to do now. Guess it's itching to try it out live now
ECU re-map was done by Porsche Motorsports in Germany. Definitely have some work to do on the dampers. Car is on the boat tomorrow and hopefully here in 2 weeks or so. Can't wait!
