Noise police- need advice
A freind of mine just purchased an 02 Cup car. I am pretty sure the thing is going to blow well over the 94dB limit. What are Cup owners doing when they run DE's in order to stay within regulation??
Thanks in advance for your help.
future Cup car owner,
05 996GT3 (full cup suspension)
07 GT3RS
07 GT3RS
07 GT3RS
07 GT3RS
We can talk about this also on Thursday, see ya then.
I had small tabs welded to the exhaust pipes and my extensions . The extensions slide inside the factory outlets and bolt right up. The foam is really important especially with your 7-cup and it's larger throttle body. IIRC the 7-cup guys have to use a larger piece of foam the fills up the entire rear deck....
![](http://img389.imageshack.us/img389/3659/picture017ru1.jpg)
![](http://img389.imageshack.us/img389/3223/picture018dk2.jpg)
![](http://img392.imageshack.us/img392/4876/picture019sj2.jpg)
![](http://img392.imageshack.us/img392/7010/picture020tw8.jpg)
![](http://img392.imageshack.us/img392/5551/picture021uo1.jpg)
Mike I can't remember where the foam came from but it wasn't anything special. Contrary to what you would think, the intake is the source of most of the noise coming from the motor. You can see I aimed my exhausts away from the passenger side which is where the monitors are at Laguna, but that's only half the battle. The noice that eminates from the throttle body is just as important. I found one pic from last summer at Laguna. If you look real close ypu can see the yellow foam covering the rear deck lid....
![](http://img294.imageshack.us/img294/6909/img2113ge7.jpg)
