Porsche Cup Cars
Steel lower control arms? GTC3 and GTC2
Old 03-07-2019, 08:18 PM
powdrhound
powdrhound's Avatar
Received 1,723 Likes on 1,003 Posts
Originally Posted by spiller
Can the factory cup control arms be modified to accept these pins? I also have a tough time believing the arm itself would actually fail.
The forged body of the Cup and RSR arm is the same. The outboard portion is machined differently to accept the rose monoball which is not sold separately by PM. So the answer is yes and no.
With that said, I’ve never seen or heard of a failed forged RSR LCA. I would always put my money on the PM arms which are battle tested on cars running races like 24hrs of LeMans over some aftermarket arms designed in someone’s garage. I never understood the infatuation with some of these aftermarket parts.
Old 03-08-2019, 08:03 PM
spiller
spiller's Avatar
Couldn’t agree more. I would only ever resort to using A/M if the Porsche Motorsport parts became NLA.
Old 03-10-2019, 09:52 PM
rbahr
rbahr's Avatar
Having looked at and owed some of the options, I completely agree with John.
Ray
Old 03-22-2019, 08:28 PM
Tarett Engineering
Basic Sponsor
Tarett Engineering's Avatar
Originally Posted by Phokaioglaukos
Don't look GTC3 legal.
They have the same geometry as the OEM arms.
Ira
www.Tarett.com | Sales@Tarett.com | 858.674.5573
Check out our new Suspension Package Designer
Old 03-22-2019, 10:13 PM
Phokaioglaukos
Phokaioglaukos's Avatar
Ira
Hi Ira, the geometry may me able to be the same, but the arm is not the same.
Your web site explains: "Camber, caster and wheel base can all be adjusted quickly and precisely with a simple turnbuckle link design. No shims to add or remove. In addition, this kit includes precision adjustable diagonal links for fine tuning caster and adjusting wheel base. All pivot points, at the chassis connection consists of oversized precision grade Teflon lined rod ends. The ball joint also consists of oversized precision grade Teflon lined monoball bushings. The diagonal link to the chassis connection point uses the 997 RSR design which allows it to be raised or lowered to reduce squat and dive during acceleration. For safety, the problematic 12mm ball joint design, used on both OEM and aftermarket arms, has been completely redesigned for a full proof, significantly stronger, and more reliable design that you can count on. To top off this no compromise design the center geometry can also be adjusted to correct for lower ride heights."
That all sounds as though your arm is superior to the OE arm. A goood thing, but it does not seem to meet the 2019 PCA Racing Rule: "GTC2 and GTC3 cars are allowed to replace the pressure-cast aluminum control arms with steel control arms of identical dimensions." Identical to my mind is identical and not with the other adjustments. The Fabcar item that the rule seems to be written for is identical, if NLA.
Quick Reply: Steel lower control arms? GTC3 and GTC2
