Twin-Plug Conversion
I have a 1969 2.0L longblock S motor that I plan on dropping in my 1968 911 USA. Does anybody have an cost estimate on the machine work required to modify the heads for the additional plug?
Any help would be a plus. This is a long-term project. The car currently has the original motor with 54,000 miles. Its my joy, but I want some additional powere that's why I bought the second engine.
Thanks in advance for your comments.
<strong>Howdy all.
Thanks in advance for your comments.</strong><hr></blockquote>
Hi:
JMZ offered you some sound advice about the twin-plug hardware. These heads were the most octane sensitive ones when the compression ratio approached 10:1 and twin-ignition is highly recommended here.
We charge $375 for machining your heads & lower valve covers for twin-ignition.
Hope this helps,
How difficult is it to modify an existing distributor to a dual distributor? What are the pitfalls? Are single head distributors too exotic and expensive to consider? I have heard MSD is a prefered ignition box over the permatune for this type of setup. Any qualifications? How important is plug selection for this type of setup?
Lots of questions, thanks in advance.
<strong>thanks for the replies...more questions on the subject.
Lots of questions, thanks in advance.</strong><hr></blockquote>
Hi:
Well, the options are more limited for the present as the Bosch RSR caps & rotors are no longer made and one cannot convert the normal distributors to twin-plug operation anymore.
With the early cases (2.0-2.2 litre), all you can do is install a crank-fire unit like Electromotive and hope for the best. The late mag cases and all aluminum cases will accept the 3.6 dual distributor (along with some other hardware) and trigger a pair of MSD's and coils.
Hopefully, in the near future, the RSR caps and rotors will once again be available and make this whole thing much easier,..
Aaron Burnham creation...once unobtanium...
6 more holes in 69S Spec Engine! Going to run with Webers...
Custom panel for SWB side by side SWB & LWB Twin plug panels
Jim Tidwell Custom Panel w/ Kroon Custom Harness
Twin 14 Pin Harness, by Kroon.
Hopefully the last few steps won't take 13 more years!!!
