Nitrous Injection
8th Gear
Nitrous Injection
Good evening folks
I've not long ago bought a 944S2 which is very pleasing but could do with a little more get up and go... I want to use it for track days and was thinking of Nitrous Oxide injection but there seems to be little discussion on the subject... The method I'm looking at is to only "inject" when the throttle is fully open. Has anyone ever tried this ? Some advice please if you have.
Bill,
Injecting at wide open throttle is the preferred method of using NOS. Most applications use a button that is mounted to the firewall. When the nitrous is activated, usually by a separate switch, and at full throttle the accelerator pedal actuates the button and nitrous is injected. You will need to run fuel to be injected with your nitrous. I think Nitrous Oxide Systems has a kit for your application.
http://www.nosnitrous.com/HiOctn/Pro...S/imports.html
Jim Nowak
Jim Nowak
8th Gear
Jim
Thanks very much. I have looked at the Holly NOS Systems on the web and the system I'm thinking of going for is the same. I guess my real problem is that I don't know what it will FEEL like... I'm told that a 25bhp increase is dramatic with NOS as it increases the power right the way through the range. I've also got some concerns about how much NOS is used... I believe I can get about 26 minutes of "activation" for $150 of NOS. I'm happy to pay this for a Track Day but don't know if it's enough (I think it may be given a typical track day gets you on track for about 2.5 hours and the system is only delivering NOS when my foot is flat to the floor). Sorry guys, I know my lack of experience is showing here but can anyone who has actually driven a NOS assisted car give me some guidance here.
Many thanks
UK Bill
Many thanks
UK Bill
I had an NOS kit on my Supra and I would say that it's fine for drag-racing, but for track usage, it won't help you much. That's because of its all ON or OFF nature, nothing in between. But there are progressive controllers on the market now that will make the transistion more natural.
You should definitely read up on Doug's NOS adventures on http://www.nsxfiles.com/stories.htm, specifically Chapter-69.
If you've got a 20-lb bottle, that will give you about 2-3 minutes of full-throttle NOS usage. At the track, that is about 5 laps.
So I agree with Chris, enjoy your car as much as you can by getting more track time in. If you want something with more speed and power, I'd buy a car that has those specs to begin with in stock trim. Much, much, much cheaper and more reliable in the long run.
8th Gear
Thanks very much for all the input guys.. I'll give it some thought and get a few days on the track with it before going too far.. I do intend to stiffen the suspension a bit before doing anything else but your input has helped me to decide at least to delay a while befor edoing anything too dramatic. I've also got some more research to do based on your input.. The sales guys told me the power uolift was smooth and that I'd get about 25 mins from 20lb. Once again thanks and good luck.
Bill
Bill
Here's what I have learned.....
First upgrade.....Tires
Second upgrade.....Brakes
Third upgrade....Suspension
Fourth upgrade....Your Ability
LAST UPGRADE.....ENGINE/POWER
IE....don't bother with more power till you have a way to use it and you know how to use it.
im hoping within a few months, i'll have nitrous in my 944....right now im gathering some parts up to redo it...
i have 944 turbo s pistons, new rings, gaskests, forged rods, clutch, 944s2 tranny, etc....im going to replace to run a supercharger then im going to add about a 75-100 shot of nitrous to it...that should give it some go....
Bill,
I'm afraid that I'll have to agree with QuikStuf993, except that I would say upgrade your ability first. Did my first Drivers Ed last month and discovered that I'm not the great driver that I thought I was.
If you've not done any DEs, then you are the weakest link!
$.02
Tye
89 S2
Yellow Koni's, LSD
$.02
Tye
89 S2
Yellow Koni's, LSD
